just installed intake. HELP!!!
Old Mar 13, 2009 | 09:52 PM
the senile J's Avatar
i just installed my injen SRI. sounds great btw but my speedometer does not light up anymore. i thought i had heard of this happening before but i couldn't find it in the search. can someone please help?
Old Mar 13, 2009 | 09:57 PM
Coblasts's Avatar
You checked all the connectors around the area you were working.
I cant see how the install of the intake could have anything to do with the speedo lights not working.
Stupid question but could your dimmer be turned the wrong way.
Old Mar 13, 2009 | 10:02 PM
dimmers on all the way. my friend messed with the negative terminal and touched it on the battery a couple times on and off so maybe i blew a fuse?
Old Mar 13, 2009 | 10:14 PM
Coblasts's Avatar
Theres a fuse in the bcm called cluster check that one.
Old Mar 13, 2009 | 10:28 PM
whats that fuse called in the owners manual? if you could look for me that would be great.
Old Mar 13, 2009 | 10:44 PM
Coblasts's Avatar
CLTR fuse #7 10 amp
Old Mar 13, 2009 | 10:58 PM
chevysssc's Avatar
friends dont let friends work on thier car
Old Mar 13, 2009 | 10:59 PM
he was helping and i let him undo the battery. haha but youre right
Old Mar 13, 2009 | 11:12 PM
Coblasts's Avatar
Hey another question
Does the light turn on when you turn your head lights on manually.
Old Mar 13, 2009 | 11:16 PM
i tried that and no it doesn't come on. i haven't had time to check that fuse yet so i'm hoping that's it but keep throwing ideas out anyways.
Old Mar 13, 2009 | 11:30 PM
Coblasts's Avatar
Only a few thing can cause them not to work.
Bad wiring to the light.
BCM gone bad
Bad connection to BCM
Day light sensing unit gone bad
Dimmer switch failed(Im leaning towards this one)
Old Mar 13, 2009 | 11:58 PM
but what would cause that dimmer switch to fail if you think that's it and how would i go about fixing it?
Old Mar 14, 2009 | 10:16 AM
morning bump
Old Mar 14, 2009 | 08:35 PM
ttt!
Old Mar 14, 2009 | 10:56 PM
Coblasts's Avatar
Theres a procedure for jumpering out the dimmer switch with a fused jumper wire to bypass the electronic dimmer part of the switch to see if that is the problem.
Old Mar 15, 2009 | 01:05 AM
do you by chance know that procedure? and if it was the dimmer switch could i just go to the dealer and order another switch?
Old Mar 16, 2009 | 03:16 AM
i fixed it. thanks for all the help.
turns out there was a short in the headlight wiring harness from when i still had the gen 1 projectors.
a little electrical tape and a new parking lamp fuse did the trick.
thanks guys.
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
OrangeCoba
Sep 25, 2015 06:06 PM
