Key stuck in ACC/ON position...
Old Nov 21, 2010 | 04:26 PM
bruceg's Avatar
Driving home from a friends house...pull up in my driveway and yeah...key is just stuck in the on/acc position...wiggling the steering wheel wont get it out.
I read that some models have some sort of hole with a spring or some sh*t under the steering wheel and if u push it or pull it it comes out...but there is no hole like that on mine
The worst part is the only way to get the damn car to shut off is by purposely dumping the clutch with my e brake on to stall it...
Also, it's aggravating as hell because I have to keep unhooking and hooking up the negative on my battery so the damn thing doesn't drain.
I'm so sick of all the problems with this thing... First the annoying power steering...now this stuff...
This is my first and will be my last Chevy.
Anyway...can anyone help?
PS: it's an 09 Cobalt SS/TC
Old Nov 21, 2010 | 04:37 PM
RandyO's Avatar
Sounds like fucked ignition tumblers to me. I had the same problem, the stealership put new tumblers/ignition in and haven't had the problem since. Sounds like you need a trip to your dealership man.
Old Nov 21, 2010 | 05:00 PM
jsscooby's Avatar
same thing with me. For mine I think they replaced the whole cylinder. Gave me new keys and all.
Old Nov 21, 2010 | 05:07 PM
09sscalicobalt's Avatar
its a recall just like the power steering and ic pipe grommet take it to the dealer stop whining and being a bitch at least there gonna take care of it for free and how long has it been like that? the first time it did it to me i drove it to chevy dropped it off and the fixed it for free and had car back next day
Old Nov 21, 2010 | 05:29 PM
b_faulk75's Avatar
That is incorrect, it's not a recall, it is a common problem, all they need to do is repair or replace the ignition tumbler. Simple fix, poor design!
Old Nov 21, 2010 | 05:42 PM
heres another post about the same thing
https://www.cobaltss.net/forums/prob...rn-off-224918/
Old Nov 21, 2010 | 06:07 PM
Erod's Avatar
Moderator Alumni
Keep this post on topic, or else. Thanks.
Old Nov 21, 2010 | 06:32 PM
biniecki's Avatar
I had a similar problem. Not sure if you have an auto or manual but with the auto the shifter contacts for park do not always engage. The car will turn off but key will not come out. I needed to have the shifter replaced to correct the problem.
Old Nov 21, 2010 | 06:35 PM
its an ss they dont make an auto and mine was an 09 ss also
Old Nov 21, 2010 | 06:56 PM
Ricer's Avatar
same thing happened to me.. dealership in Georgia took 4 ******* days to fix it.. then tried to charge me for the rental car. If you're gonna let it sit overnight either disconnect the battery or plan on needing a jump in the morning.
Old Nov 21, 2010 | 09:43 PM
biniecki's Avatar
That is incorrect. The 2.4 SS/NA comes with the option for an auto trans. The SS/SC and SS/TC are the only models that do not come with the auto trans options. With that being said an SS can be an auto but most of the time it is not.
Old Nov 21, 2010 | 10:01 PM
ok theres no auto ss/tc there ya go buddy geez...
Old Nov 22, 2010 | 12:43 AM
RandyO's Avatar
Ok kids, lets play nice ok? hahah
turbochargedss2012
Sep 20, 2023 12:17 PM
satisfied
Oct 19, 2015 12:35 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
