keyless entry
Old Sep 19, 2011 | 08:47 PM
afterlife04's Avatar
keyless entry
I've replaced the battery on one of my keyless remotes cause I thought the battery was going bad. The unlock button will unlock the car but if I hit the unlock button again, the remote doesn't respond sometimes. I've tested this out on both remotes and sometimes the unlock or lock button will work correctly other times it won't work at all. If it makes a difference I also replaced the buttons pad on the remote. I'm thinking maybe the receiver on the car is going bad? any way I can test this?
Just another note I got my BCM replaced in december of 2010.
Old Sep 19, 2011 | 08:51 PM
LSJBalt's Avatar
Everyone has a problem with the cobalt key fobs
Old Sep 19, 2011 | 08:57 PM
lol any ideas? or things to try? Before I end up wasting money at the stealership......
Old Sep 19, 2011 | 09:16 PM
nutty21's Avatar
Id recomend reading the owners manual. Havent checked it, but typically that stuffs in there.
Old Sep 19, 2011 | 09:17 PM
heathkidder's Avatar
there is a how to on this something about soldering the battery bracket down more or something check it out
Old Sep 19, 2011 | 09:22 PM
It's not the key fob....why would both of them be like that? :S Just doesn't make sense......
Old Sep 19, 2011 | 09:36 PM
it can be the connection thats bad
Old Sep 19, 2011 | 11:14 PM
Coblasts's Avatar
Like heathkidder said,check the battery contacts,they both could be broken.(weak contact)
Otherwise a trip to the dealer is in order.
They can check the incomimg signal with the Tech 2 I would think.There is no other way without specialized electronic equipment .
Old Sep 20, 2011 | 08:49 AM
Took it to the dealer this morning and their not even sure if it's the transmitter or not......but he says my key fobs are definitely working properly. Any ideas?
Old Sep 20, 2011 | 05:16 PM
Anyone have the service manual on how to replace the transmitter in the car? I know the dealer will have to program it for the car once its replaced.
Old Sep 20, 2011 | 05:29 PM
sick_tight's Avatar
my wife broke both key fobs, just opened it up and put the battery contacts back in place and stuffed the open space with a folded paper towel to stop it from having any room to be jolted out from dropping them and its worked ever since, ghetto YES but you cant tell and its been working for a year and a half
Old Sep 20, 2011 | 10:06 PM
Yeah but the problem isn't the key fobs......its the actual transmitter on the car....
Old Sep 21, 2011 | 08:40 PM
is there a fuse for the transmitter on the car?
Old Sep 21, 2011 | 08:47 PM
Went through the manual and found nothing, guess theres no fuse...If anyone has directions on how to replace the transmitter on the car please post....
Thanks.
Extreme Dimensions
Sep 24, 2015 07:51 PM
dieGone
Sep 23, 2015 10:20 AM
riceburner
Sep 2, 2015 11:06 PM
irocz85
Jun 1, 2005 09:58 PM
