Weird Engine Knock Sound (Video)
Old Sep 15, 2011 | 09:53 PM
Sam707's Avatar
Hey I have a 06 ss/sc and im hearing a weird almost knocking or clicking sound. Happens almost every time I start the car and usually stops as far as I know when I start driving.
http://www.youtube.com/watch?v=QvvIUX9Dw2Q
Help would be greatly appreciated.
Old Sep 15, 2011 | 10:07 PM
KangolRiot's Avatar
says video is private
Old Sep 15, 2011 | 10:09 PM
Sam707's Avatar
Sorry about that fixed it. Thanks
Old Sep 15, 2011 | 10:12 PM
HyperMuffin's Avatar
needs new exhaust bearings
Old Sep 16, 2011 | 07:41 PM
Gelladuga69's Avatar
I'd say it was the belt or belt tensioner, but you said ti goes away when driving.
Old Sep 16, 2011 | 07:54 PM
elecblue06's Avatar
when did he say that.. it says and as far as i know when i start driving
Old Sep 16, 2011 | 08:21 PM
Sam707's Avatar
Well its hard to tell I may not be able to hear it just because of road noise. I don't think it has anything to do with the belts though.
Old Sep 16, 2011 | 08:25 PM
Yes, as far as he knows.. Did I need to specify that?
He couldn't be for certain, because of engine and road noise..
Old Sep 16, 2011 | 08:40 PM
mexi_loco's Avatar
how many miles are on the car?
Old Sep 16, 2011 | 08:41 PM
mexi_loco's Avatar
my second question is where the noise heard from the loudest?
Old Sep 17, 2011 | 02:07 AM
Sam707's Avatar
40k Miles, Noise mostly originates from the left side of the valve cover. I've heard something about a timing chain tensioner making noise could that be my problem?
Old Sep 17, 2011 | 03:02 AM
Frogstofall's Avatar
This may sound stupid but, when was the last time you had an oil change?
Old Sep 17, 2011 | 03:15 AM
rivaladore's Avatar
Every lsj should put in the revised timing chain tensioner before stuff like this happens. Sounds are hard to diagnose over the Internet but to me it sounds like the timing chain tensioner is bad.
Old Sep 17, 2011 | 01:20 PM
Sam707's Avatar
That's what I was thinking too. So what do you think would be the best way to get this fixed get it diagnosed and do it myself? Since the bumper to bumper only goes to 36k miles?
Old Sep 17, 2011 | 02:46 PM
rivaladore's Avatar
I would save yourself the time and frustration with going to the dealer. Order the new tensioner from crate engine depot, unbolt old tensioner, put in new one......pretty simple and straight forward there is a how to on here as well.
Ecotec Timing Chain Tensioner 12608580 - Crate Engine Depot
Old Sep 17, 2011 | 02:54 PM
jlong3382's Avatar
What's the temperature in your area? Mine will do that when it"s below 50F, until the engine warms up.
Old Sep 17, 2011 | 03:13 PM
rivaladore's Avatar
Just because your engine makes that sound to doesn't mean it's normal. My engine sounds perfect no matter what the temperature outside
Old Sep 17, 2011 | 03:27 PM
badbaltguy's Avatar
could also very well be a lash adjuster or rocker backing off... valve noise and things like that normally get quieter as the engine warms up.
Old Sep 17, 2011 | 09:00 PM
rukkee's Avatar
Timing chain tensioner ..... like someone said above . Make sure you take the valve cover off when you install the new one so you can engage the tensioner . Some people will say it's not nesassay but I would take the chance of installing it collapsed and hoping in engages the right way.
Old Sep 18, 2011 | 01:40 AM
rivaladore's Avatar
There is no setting the revised tensioner like the original tensioner. The new tensioner applies tension with oil pressure not a spring like the old one.
Old Sep 18, 2011 | 09:27 AM
rukkee's Avatar
Unless their are three revisions of the tensioner ..... I accidentally released the revised tesioner when i pulled it out of the box ...... even the old tensioner worked on oil pressure but both have springs in them from stopping a compete collapse when the engine is turned off (IE no oil pressure)
Old Sep 19, 2011 | 08:04 PM
Coblasts's Avatar
Just had mine changed at the dealer last week,under goodwill.
They didnt remove the cover.
If i find the instruction on replacing the new revised one(3rd revision so far since 06)
I will post it.
Old Sep 21, 2011 | 08:54 PM
rukkee's Avatar
I will post it.
Ahh... makes sense now . When i did mine back in 07 it was a new revised tensioner at that time ..... now with there being three It could be totally different to install compared to Rev.2
Sl0wbaltSS
Nov 21, 2018 11:11 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
