Knocking in steering column
Old Sep 30, 2013 | 11:14 PM
BallinBlackbaltSS's Avatar
I keep getting a knocking in my steering column and was wondering if any one else had the same issues i have an 06. When i hit about 65 it starts to knock pretty hard, if i turn slightly to left it usually stops or turn slightly to right it stops but then comes back. any ideas what i should be looking for? When it knocks I'm on pretty flat surface even not bumpy. I really have no idea but it drives me insane! Please help thanks!
Old Oct 1, 2013 | 10:39 AM
mrbelvedere's Avatar
your column could need to be greased these is a sliding insert that is connected to the universal where it connects to the rack
Old Oct 1, 2013 | 11:30 AM
theandies's Avatar
There was a recall on the steering intermediate shaft for my '06. I think that knocking is one of the symptoms. I had it done when I first had my car (brand new in '06). I do have it again though but it doesn't seem to be as bad as you are describing.
Old Oct 1, 2013 | 11:40 AM
qwank's Avatar
sounds like the steering column for sure. if it goes away when turning thats usually what it is. never seen them speed sensitive though, usually it's low speeds over bumps when they really start to go crazy.
pull out the power steering fuse and drive it, if the sound gets way worst and doesn't go away when you turn, it's the column. if not it could possibly be the shaft.
you could unbolt the shaft at the rack and cycle it in and out to spread the grease. if it goes away for a while after that, it's the shaft.
Old Oct 5, 2013 | 02:01 PM
Awesome does any one have any pictures of what i should grease? I'm not to sure what i should be looking for, thanks for all your help!
Old Oct 6, 2013 | 02:30 PM
JJohnson479's Avatar
My cobalt just started the exact same thing. I would like to know what this is and how to fix it
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
TedSS
26
Oct 10, 2015 04:30 PM
Tupp
Sep 30, 2015 08:18 PM
