Leaking Axle Seal
Old Dec 17, 2008 | 04:35 PM
RobertoSS's Avatar
Exclamation Leaking Axle Seal
So I take the car in for an oil change friday..... & they discover that the right front axle seal is leaking. (I didn't even know it) They put me in a rental for a couple of days and fix it under warranty. Turns out it was a defect from factory assembly. So take a look everyone.....it wasn't much of a leak...but it was there. Props to my dealer for doing a great job and great service.
Old Dec 17, 2008 | 06:46 PM
Sh0nuff's Avatar
mine was doing the same, just got it fixed a week ago, also had them replace the bearing while they were at it.
Old Dec 17, 2008 | 06:52 PM
TurboTechRacing's Avatar
Wheel bearing? or?
Old Dec 17, 2008 | 06:56 PM
slowswap's Avatar
My friends axle seal is leaking. Probably deformed from wheel hop allowing a leak.
Old Dec 17, 2008 | 06:58 PM
t5665y's Avatar
had that happen to may car but after being fixed there was still tranny fluid leaking turns out there was a crack in the tranny with only 500 miles on it
Old Dec 18, 2008 | 03:45 AM
rukkee's Avatar
Wow TC's are still cracking cases like the SC's were?
Old Dec 18, 2008 | 07:09 AM
slowswap's Avatar
The reason tranny cases crack is because of wheel hop. Wheel hop is caused by ossciliating forces in the rubber mounts. Factory rubber mounts suck.
Old Dec 18, 2008 | 12:19 PM
rukkee's Avatar
yep i realize that wheel hop cracks them , just suprised that all the hype from GM about fixing the problem hasn't stopped it. There was alot of talk about the tranny being updated as well with stronger internals and case.... i'm guessing that isn't true . The clutch is better but i doubt they changed the tranny much.
Old Dec 18, 2008 | 07:45 PM
Dainslaif's Avatar
Considering how badly most of these owners beat on their TCs, a few axle seal leaks compared to cracked bellhousings and grenaded synchros galore is a pretty large improvement.
Old Dec 18, 2008 | 10:45 PM
rukkee's Avatar
yeah but that other guy above cracked the tranny case within 500 miles , he had a tC aswell
Old Dec 20, 2008 | 09:03 PM
Dainslaif's Avatar
Eh, there's exceptions to every rule. That could have been cracked during shipping or something else, too.
Old Dec 22, 2008 | 07:46 PM
RobertoSS's Avatar
I haven't beat on mine at all. So mine was definitely a defect from the factory.
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Trav3480
Sep 28, 2015 02:46 PM
