Leaking from my...(NEED HELP)
While changing my oil the other day I noticed some fluid all over the bottom of my tranny...I was thinking that this is it, Im fucked now. We'll after searching around I seamed that I was leaking tranny fluid from my left output shaft (Pic B). I purchased the seal and S/O tranny fluid and was ready to replace it...well right before we tore everything apart we noticed that this fluid is coming from higher grounds (Pic A) and just running down onto my left output shaft. Now I have no idea on what this part is really called in Pic A, you can see where the fluid was coming from (I cleaned it off before the pic) and how bad this could be. HELP. Can anyone send me the GM pdf file for the F35 tranny?
IN SUM
Thought I was leaking from left output shaft seal (B), was wrong and its coming from where the shifter meets with the tranny (A). HELP.
Anyone has this problem before?
How bad is this?
How hard is it to fix?
Pic A
Pic B
IN SUM
How bad is this?
Pic A
Pic B
If the seal for the drive shaft was leaking enough the drive shaft could of sprayed it up there.
I would wait a day and take another look to see if thats the case.
Ive had that drive shaft seal replaced already.
The top pic isnt as dirty because I had already clean most of the fluid off before I snapped the pic.
From my experiance with leaks is. General rules of thumbs to go by. Follow the leak up to it's highest point. 9/10 times THAT is where the leak is comming from. Work your way down with repairs. I dont know what it would take to replace whatever seal may be leaking by your lever. But also, lookup to see if anything is tripping onto it from above.
-Jonathan
-Jonathan
n20saturn
Sep 30, 2015 12:26 AM
