Leaky Downpipe Flex Joint?
Old Dec 9, 2013 | 08:12 PM
SSlobalt55's Avatar
So i installed a ZZP long tube header/dp combo a few months ago on my 2006 LSJ…. Ever since installation i have had a raspy leaking noise coming from either below me, while driving, or it sounds like it is coming straight from the end of my exhaust ( i am also running a Vibrant catback exhaust) The noise is only heard when i reach about 4k rpm's or am creating any boost, id say anything more than 2 lbs. Has anyone else had this problem? Or any suggestions? I replaced header gasket with a copper gasket and new bolts throughout. I have also even gone to the extreme point of getting my header/dp flange welded (i absolutely hate v-band clamps). If anyone could help me it would be fantastic. I feel like the leak is making me lose power and it also sounds like complete S**T. My only idea left is that my flex joint is leaking… i took a look under the car for any resign build up but my car is undercoated so its a little difficult to tell. HELP PLEASE!!!!
Old Dec 15, 2013 | 10:32 AM
Free bump i got the same issue and think its coming from the dp/catback flange
Old Dec 15, 2013 | 10:36 AM
yellowsupercharged06's Avatar
I get a rasp at WOT with my badmab, zzp dp and stock catback like explained above.
Putting on my zzp catback today hopefully that all goes away
Old Dec 15, 2013 | 10:58 AM
blueLNFftw's Avatar
Put some copper gasket spray between any gaskets left.
Old Dec 15, 2013 | 11:09 AM
Oh yeah that did it for you right? vband too?
Old Dec 15, 2013 | 11:57 AM
SSlobalt55's Avatar
Well i have that flange literally welded up!!!! So that's not the issue. and a copper gasket was put on the header. ***** tweaking me out lol I just want to figure it out.
Old Dec 15, 2013 | 01:38 PM
blueLNFftw's Avatar
The SCE one? Lots of complaints those leak.
Old Jan 18, 2014 | 04:59 AM
SSlobalt55's Avatar
sorry to comment on my old forum, but yes that one… you've heard a lot of complaints with it? i just had the car checked out by my mechanic and he couldnt find any leaks. He said either their is a vacuum leak elsewhere or it is leaking nearer the header.. any suggestions? or should i replace the gasket?
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
