Lean code on a stock car
Old Feb 22, 2006 | 06:18 PM
DarthDalla's Avatar
I am not sure that this is the right section, but this morning on my way to work I threw a code, I went to Autozone and checked out the code and its a lean code. My car is bone stock has anyone else threw a lean code on a stock car? and does anyone have any insight on why? I plan on takin it to the dealership tomorrow but want some peace of mind that this isnt my fault.
Thanks in advance for any help
Old Feb 22, 2006 | 06:33 PM
MarcS's Avatar
The Stig
Happened to me twice.
It's not your fault.
They'll read the code, kick the tires, check your connections, but won't find anything. They'll reset it and tell you they tightened something.
Old Feb 22, 2006 | 06:43 PM
bluechevyss05's Avatar
omg i just made the sam post without reading yours first, how many miles on yours, mine came on at 8k.
Old Feb 22, 2006 | 11:29 PM
DarthDalla's Avatar
I have almost 6k on it. Do you think I am actually running lean or there is a bad sensor?
Old Feb 23, 2006 | 09:43 AM
1ecoss's Avatar
There is a bulletin out for stock setups regarding this code. It has various opinions on what throws the code from wrong filter numbers to the pleats on the filter being tightly packed which causes the airflow around the MAF sensor to be misread. The dealer will most likely check to see if the bolt has rubbed through the snorkel tube in the engine bay, tighten all connections, and possibly turn the filter 180 degrees. These are GM's solutions to the problem. I threw the lean code with my K&N and the dealer showed me the bulletin to show that it is a common malfunction as well as what GM is doing to correct it.
Old Feb 23, 2006 | 09:52 AM
R33P3R007's Avatar
360 L337 User
I had this about 4500 - 5000 miles. took it in and they did what MarcS said.
I am now just getting into problems with me car idleing funny. only if I am stopped at a light or something. it drops way down then goes up and down. no problems with idleing at all now at 9000 miles it starts.
1ecoss's Avatar
Old Feb 23, 2006 | 09:54 AM
Chevypowered's Avatar
This is wierd, some of you are getting this code with a stock car. I on the other hand was running lean for a few days and never got any code and i have never got a code exept for once with my air box mod. Is my car a factory code freak?
Old Feb 23, 2006 | 01:07 PM
bluecobaltss06's Avatar
Actually I see this happen at the shop all the time. Gm is having a lot of problems with cobalts throwing a P0171 code. At the moment there is no fix for it, according to the bulletin. Just wait it out, and GM will come out with a reflash...hopefully.
Old Apr 12, 2007 | 02:02 AM
teh_punk's Avatar
i got it when i put my intake on.. then when i put on the ss/sc headers and catback exhaust it went away...
Old Apr 12, 2007 | 02:05 AM
KillerBee's Avatar
Yeah mine ran lean when i put my Injen intake on so i had to take it off until i get a upgraded stage kit lol
vjoel2011
Oct 2, 2015 12:11 PM
ATOMbomb
Sep 11, 2015 10:48 AM
Josh@ottp
Sep 8, 2015 10:18 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
