Light Issues
Light Issues
Last night I got in my car and started driving home from where I was and I looked at my gauges and they were not lit up. Tried turning the dimmer knob incase I had some how dimmed them but no luck. Switched the lights from auto to manualy on and nothing. Got home and the only lights on outside of the car were the DRL's. The Taillights, parking lights, and low beams were not at all. But if I flip a turn signal on the Parking light bulb flashes like it suppose to and the tail light as well (except the driver side tail bulb is burnt out for the turn function). If i hit the brakes the lights come on.
So I am gonna look at fuses now but looking at the cover not sure which one it would be. Of not when I flip left turn on my indicator in the car flicker super fast as well ( I believe due to the burnt out bulb.)
Thoughts?
Thoughts?
I believe its the parking lamp fuse. 15amp maybe. It runs ur cig lighter, dash lights, license plate light and rear running lights. Ur tails work with 1 bulb that switches resistances when u use the brakes or just have running lights so changing the bulb will not do anything. Check ur fuse, im almost 100% sure its ur park lamp fuse thats blown
