lighting/info button issue
Hi Guys,
having an issue with my Info button...2008 SSTC.
When i turn my hids on, the infobutton does not cycle the DIC. everything else works. tried with and without relay.
when my hids are off and i turn on my fogs, the infobutton does not cycle the DIC, everything else is perfect!
when all lighting is off, works perfect!
thoughts?
thoughts?
Check the volts coming out of the light switch and dimmer.. might also be a nice idea to get a diagram from your local dealer as how the power is supplied and how ground is distributed.. u might have weak resistors somewhere in the cluster.. check for burned spots..
