lighting/info button issue
Old Aug 2, 2013 | 06:20 PM
wol-shiver's Avatar
Hi Guys,
having an issue with my Info button...2008 SSTC.
When i turn my hids on, the infobutton does not cycle the DIC. everything else works. tried with and without relay.
when my hids are off and i turn on my fogs, the infobutton does not cycle the DIC, everything else is perfect!
when all lighting is off, works perfect!
thoughts?
Old Aug 4, 2013 | 03:49 PM
wol-shiver's Avatar
Old Aug 4, 2013 | 10:55 PM
wol-shiver's Avatar
Originally Posted by wol-shiver
Update. Having fogs and hids on - and lowering cluster intensity to the lowest setting results in my info button working. Im at a loss.
Old Aug 6, 2013 | 12:23 AM
gm_gtp_sc's Avatar
Check the volts coming out of the light switch and dimmer.. might also be a nice idea to get a diagram from your local dealer as how the power is supplied and how ground is distributed.. u might have weak resistors somewhere in the cluster.. check for burned spots..
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Cobalt_Daddy
Sep 27, 2015 06:59 PM
