limp mode
Old Mar 20, 2013 | 01:01 PM
MichiganSS's Avatar
limp mode
I know this has been discussed at least once but im hoping to get a direct answer and fix from one of you knowledgable fellow ss owners ..
My 05 SC lsj keeps going into engine power reduced mode, when this originally happened my car was throwing about 7 codes varying from accelerator pedal position sensor, to o2's, intake air temp sensor, etc... I cleared them and drove again with the scanner plugged in, car went back onto EPR/limp mode and I checked again.. Three codes, acell. Pedal position sensor, and something else, and then a repeat of the first
So I replaced the throttle body yesterday with a brand new one, thinking maybe I fried the sensor and actuator when I cleaned the TB with tb cleaner.
I replaced the tb assy. And did a tb relearn by unplugging ecm fuse inside, nothing.. Still went into limp mode.. So today I disconnected my battery for about 10 mins hoping It would reset it all and fix the issue...no luck, just down the road it popped into epr mode again under acceleration.
What's the deal??
Im needing some insight here if any is available, this problem is driving me nuts
The only other thing i can think of replacing maybe would be the MAF?
But even that dont seem like it would cause my issue...
Im outta ideas
My mods are -stage 2 injectors, 2.7 pulley, full corsa exhaust, and in the summer an Injen cyborg cold air intake
This problem seems to have arose after i did two things...
The first being initially cleaning my TB (which I removed from the car so i didn't get **** in the supercharger)
And when i killed the battery a few weeks ago
I tested the battery today at auto zone and it tested fine
Also today their obd2 scanner said it was throwing TWELVE (12) CODES
So obviously the new TB has opened up more?
I have no clue
Im horrible with electrical
Any help is appreciated immensely
This ***** is my DD :/
Old Mar 22, 2013 | 09:48 PM
Nabes07SS's Avatar
What codes are being stored?
Old Mar 23, 2013 | 07:30 AM
usafcobalt's Avatar
Could be the app. Which is the pedal assembly itself. Does your scanner do data? Or commands?
Old Apr 9, 2013 | 01:26 AM
yellowssbolt's Avatar
I have the same problem on my sc...I replaced maf...crank...Cam..and mapping sensor and still I get that limp mode I don't know wat it is either I NEED HELP!!!!!
Old Nov 10, 2014 | 10:21 PM
I had that problem in my 06 ss...it's your purge valve...facing the engine bay..right top of supercharger..a little hose(2 button)
Old Nov 11, 2014 | 02:59 PM
tomj77's Avatar
I'm pretty sure the as peddle also has a sensor that works with the throttle body, code sounds like that what u should be changing. Anyone can confirm this?
Old Nov 13, 2014 | 09:54 PM
Had that happen a couple of times when I had my 06 Cobalt
Old Nov 16, 2014 | 01:20 AM
06 cobalts had a lot of problems...check your purge valve...google images
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
Dustonian131
Sep 23, 2015 08:03 PM
bucks121
Sep 12, 2015 07:39 PM
