Little Help Needed jacking up the car
Old Mar 15, 2006 | 12:12 PM
mkulrey13's Avatar
Ok so i have a sedan, i am cleaning the wheels and would like to have the car sitting on stands. I have the back all jacked up on stands but i do not know where to put the 2-ton jack to jack up the front. There is no noticable axle like the back. Just want to make sure i put it in the right place before it goes boom :P please let me know
Old Mar 15, 2006 | 12:16 PM
freakaccident's Avatar
There is a crossmember in front of the engine you can use.
Old Mar 15, 2006 | 12:17 PM
StreetDreamz's Avatar
There are two jack points on either side of the front, that is the recommended way to do it. In the back you should NEVER jack on that cross brace. Watch it bend when the car gets higher. Lol.
Old Mar 15, 2006 | 12:26 PM
mkulrey13's Avatar
where do i jack it up then? ive done the back a few times and its never bent?
Old Mar 15, 2006 | 12:34 PM
Hutch's Avatar
Play safe......invest in ramps. Not that expensive and they won't fail when your under the car. (Also do it on flat ground and block the wheels that aren't on the ramps.)
Old Mar 15, 2006 | 12:37 PM
mkulrey13's Avatar
well when i need to rotate... ramps dont let wheels be free. ramps good for oil changes? leave it on the ramps let oil drain and such. I plan on rotating my own tires and oil changes after my warrenty is up.
Kinda hard to use ramps when you need the wheels off of the car.
You can either follow the manual and jack from the pinch rails or use the front crossmember for the front and pinch rails for the rear. I wouldn't jack under the rear suspension beam.
Old Mar 15, 2006 | 01:21 PM
mkulrey13's Avatar
can i put jack stands on teh pinch rails or no?
Old Mar 15, 2006 | 01:25 PM
CobaltCowboy's Avatar
i set my jacks under the pinch rails and it was fine
Old Mar 15, 2006 | 01:27 PM
RedBaseBolt's Avatar
I tried using the pinch rails and they just bent to **** on me.
Old Mar 15, 2006 | 01:51 PM
Make sure that you are setting the jackstands under the pinch rails where the notch is and it is doubled up. It will bend if you just put it anywhere along the pinch rail. I put two jack stands under the front crossmember and two under the rear part of the pinch rails.
Old Mar 15, 2006 | 02:02 PM
sorry, forgot to mention i did put the stands where those notchs are.
Old Mar 15, 2006 | 02:14 PM
Hutch's Avatar
DOH......Now here is ther eason why I hate Flu meds. Sorry about that.
Old Mar 15, 2006 | 05:29 PM
mkulrey13's Avatar
haha alright so its safe to put jack stands on the side of the car on the pinch rails? the front cross thingy? what it look like? sorry but i dont wanna **** something up lol
Old Mar 15, 2006 | 07:04 PM
zinner's Avatar
Moderator Alumni
I just put the jack stands on the subframe between the two mounts for the A arms.
Old Mar 18, 2006 | 11:45 PM
BlwnGP's Avatar
Anybody else notice the little arrow indentations on the lower rocker panel extensions (probably SS only)? Those are indicators for jack points, they are located behind each front wheel...use those.
Old Mar 19, 2006 | 09:36 PM
Asstyme's Avatar
How do you place the jack stands in the rear notch points when the jack needed to lift the car is in the way ???
Old Mar 19, 2006 | 09:54 PM
inhale's Avatar
put the stands under the control arms
GaryGibblez
Jan 14, 2020 10:35 AM
How to Guide
57
Oct 15, 2015 11:56 AM
OrngBalt
Sep 16, 2015 07:45 PM
SS_2009_TC
Sep 4, 2015 10:48 AM
