low boost on 2.7 pulley
I have an 05 ss/sc with 60# injectors, ottp he, 2.7 pulley, pacesetter header, zzp catless 3" dp and zzp 3" full exhaust. All tuned on HP Tuners. Was boosting around 18lbs now wont go above 12lbs. I have an aeroforce gauge and manual boost gauge reading the same. Need to know where my problem is. Any help is greatly appreciated.
you could try doing the boost bypass mod to see if the bypass valve is opening to limit the boost. if you do the mod and you build your usual boost pressure then you know the bypass valve is opening. i wouldnt continue to run it like that tho because there must be a reason for it to be opening.
Ok. Ive tried to look the mod up multiple times but the pics never load for me. So in turn I dont actually know how to do the mod. Could you help so I could see if its the bypass
Never figured it out. I did all the mods and still nothing. Im assuming since my tensioner is roaring like a bad wheel bearing that is probably causing my issue. Or at least hoping its my issue
patooyee
Oct 1, 2015 01:07 PM
