LSJ: High IAT temps. Thoughts needed
Old Feb 23, 2014 | 10:17 AM
blueLNFftw's Avatar
2006 SS/SC
My IAT2 is getting stupid high really fast. If I do a pull from about 3.5k in second gear, by the top of third my IAT2 is up to 165 degrees.
Normal IAT2 cruising around is 30-40 degrees above ambient, but as soon as I pull on it, it shoots up at a ridiculous rate.
Now I know the pump is good, and I checked it again. I have a FMHE and option B on the car. 3" RD Fab intake, Injen filter, 3.06" pulley, 60's, and a long tube header.
I need some ideas on why it would shoot up like that so fast
Old Feb 23, 2014 | 10:25 AM
TStone's Avatar
how do you know the pump is good..........
Old Feb 23, 2014 | 10:27 AM
blueLNFftw's Avatar
Because I can hear it as well as see gurgling fluid in the option B tank every once and a while if I switch my car to ON and watch it.
Old Feb 23, 2014 | 10:35 AM
06cobaltncng's Avatar
no kinks leaks or anything of the such I assume? all the air out of the system? im sure you checked all that. you know more than I do lol.
Old Feb 23, 2014 | 10:50 AM
yellowsupercharged06's Avatar
I would double check the lines,
Run the car with the cap off of the opt b tank and see how much air comes out.
Old Feb 23, 2014 | 10:56 AM
blueLNFftw's Avatar
I will add that I have not service the aftercooler system in about 6 months. I installed the option B, FMHE, and brand new pump at the same time.
I will check the lines, but there are no leaks in the system, this I am sure of.
Old Feb 23, 2014 | 11:46 AM
Spawne32's Avatar
Unless your measuring the actual flow rate, just because you see it moving doesnt mean its working properly. Pump failures can happen gradually where the RPM's progressively slow down to the point where it does nothing, sounds like your experiencing this now.
Old Feb 23, 2014 | 11:48 AM
Spawne32's Avatar
I'm going to be using something like this on my system to monitor flow rate.
In-line Flow Meter (Poly 2-20 gpm)
Old Feb 23, 2014 | 03:29 PM
blueLNFftw's Avatar
Those are north of $150...
Its possible my pump is shitting out. It has 10k on it, but I did get my car stuck in the sand last weekend. Was buried up pretty high; high enough that the pump motor may have sucked in sand.
Old Feb 23, 2014 | 08:35 PM
andrewcarr1993's Avatar
So how are those 60's working for you?
Old Feb 23, 2014 | 08:46 PM
southal cobalt's Avatar
something sounds wrong. my iat2 hits 160 from a similar pull with a 2.8 in 100* weather with high humidity. and im on stock cooling
Old Feb 23, 2014 | 08:51 PM
Spawne32's Avatar
on stock cooling with a 2.8 pulley i would think that would be expected, you need to have a dual pass and a upgraded heat exchanger at the very least to keep those temps low with a 2.8 pulley.
Old Feb 23, 2014 | 09:14 PM
yeah, i was just providing a comparison. im not too worried about it.
Old Feb 23, 2014 | 09:26 PM
blueLNFftw's Avatar
Awesome. My car is SO SO happy. I actually think the 42's I have are cooked. The car would spike rich when I closed the throttle on them, as if they were stuck open. The harness didn't work, looks like it is for the 2.2 or 2.4 and that it was a handmade one. I used the brand new harness from my 80's for them.
Thanks again!
Old Feb 23, 2014 | 09:29 PM
chris88z24's Avatar
You have the pump set up to come on without the car being started in your tune?
Old Feb 23, 2014 | 09:44 PM
Glad it worked, figured the harness wouldn't work that's why I was okay letting it go for a cheaper price.
Old Feb 24, 2014 | 07:15 AM
blueLNFftw's Avatar
Yup.
I guess sans a kink in one of the lines the pump just isnt pumping hard enough. I have been wating my IAT2 hard on my config while I am driving and the temps are coming down very slow.
Old Feb 24, 2014 | 07:26 AM
Staged07SS's Avatar
Administrator
Administrator
Once bled, the opt.b tank shouldnt really gurgle anymore.
Check all of your lines, and make sure they are hooked up correctly.
Old Feb 24, 2014 | 07:33 AM
blueLNFftw's Avatar
I can't remember how I hooked it up. I think it it:
pump out > laminovas > stock HE > FMHE > pump in
I am going to have to get under it I suppose. I hope there is just a kink in the line.
Old Mar 1, 2014 | 07:08 PM
blueLNFftw's Avatar
Problem resolved.
A hose clamp snapped but did not fall off. Instead it wedged between the bottom radiator bracket and the hose. There seemed to be enough pressure against the hose to keep it from leaking but it was letting air in (explains the gurgling in the option B).
Anyways, new clamp and new coolant with some water wetter and the temps are all good.
Turbo Johnny
Feb 21, 2019 09:41 AM
Superslowbaltt
Sep 22, 2015 10:24 AM
Superslowbaltt
Sep 21, 2015 07:50 PM
n20saturn
Sep 17, 2015 01:55 AM
twilson380
Sep 14, 2015 10:52 AM
