lsj timing
Old Jan 26, 2014 | 06:51 PM
josh6854's Avatar
lsj timing
Where are the marks to time my car? Ive replaced the sensor and now anything over 3grand then car engine reduced comes on
Old Jan 26, 2014 | 06:55 PM
574's Avatar
574
Under valve cover on cam gears and on the chain. and under front cover on sprocket. If you look they won't be lined up though
Old Jan 26, 2014 | 06:56 PM
mrbelvedere's Avatar
op what did you replace what sensor
Old Jan 26, 2014 | 07:04 PM
josh6854's Avatar
Cam postion sensor. So do I need to turn the crank pulley till it lines up?
Old Jan 26, 2014 | 07:13 PM
josh6854's Avatar
Old Jan 26, 2014 | 07:36 PM
574's Avatar
574
Lol bumping for ten min? Look at the cam install on here. Explains how to time engine and set cps
Old Jan 26, 2014 | 09:06 PM
follow this
next time post your car problems in problems and service
Old Jan 27, 2014 | 02:33 AM
josh6854's Avatar
Originally Posted by mrbelvedere
follow this
The notches are aligned but it will not slide in. Any help?
Old Jan 27, 2014 | 08:13 AM
did you put the engine on tdc compression stroke
Old Jan 27, 2014 | 09:09 AM
Staged07SS's Avatar
Administrator
Administrator
This.
The CPS housing should slide right in to the hex on the exhaust cam if the car is properly timed/lined up.
Make sure the mark on the crank pulley is lined up with the mark on the front cover.
cam gears will be as follows: intake 2 o clock exhaust 10 o clock.
Old Jan 27, 2014 | 01:24 PM
josh6854's Avatar
This.
Where is the mark on the timing cover? 5 o'clock
Old Jan 27, 2014 | 01:56 PM
Staged07SS's Avatar
Administrator
Administrator
The mark is on the outside of the front cover (timing cover). You need to rotate the crank pulley to line up with it.
There is a notch on the back side of the crank pulley. Line the notch with the mark on the front cover as seen in the first image i posted.
The cam gears should be in line the way I have them shown in the 2nd image.
Follow the image mrbelvedre posted and my 3rd photo for the cps housing to align it correctly. Should slide right into the exhaust cam hex w/o issue.
Old Jan 27, 2014 | 02:59 PM
josh6854's Avatar
Thanks alot I'll update later today.
Old Jan 27, 2014 | 08:04 PM
josh6854's Avatar
Cam housing went in smoothly and notches were aligned. What else is wrong cam sensor itself?
Old Jan 27, 2014 | 10:05 PM
did you put #4 tdc compression
Old Jan 28, 2014 | 03:42 PM
josh6854's Avatar
Is #4 on the driver side and if so how do you go about it being tdc
Old Jan 28, 2014 | 03:54 PM
take the spark plug out put a compression tester in #4 cylinder rotate the engine by hand till it builds compression you can then either line up the marks on the front cover or put a long screwdriver down #1 and rotate the engine till the screwdriver stops going up then install the cps housing this stuff is not hard take it to a shop if need be
Old Jan 28, 2014 | 04:44 PM
josh6854's Avatar
#4 is the first one on the driver side?
Old Jan 28, 2014 | 04:45 PM
josh6854's Avatar
Also does the belt have to be removed?
Old Jan 28, 2014 | 06:09 PM
to see the timing mark yes
Old Jan 28, 2014 | 06:45 PM
jp1600's Avatar
shove a paper towel in there, when you hear a hissing or the paper towel comes out shove a screw driver in there and rotate slowly until it hits its top range, then shove the cam thingy in. Simple enough? Done it twice now, first time took me 20 minutes
Old Jan 29, 2014 | 12:17 AM
josh6854's Avatar
Should all the spark plugs be pulled out while doing this? I'm just tryin to understand everything correctly
Old Jan 29, 2014 | 07:21 AM
Staged07SS's Avatar
Administrator
Administrator
Guys this isnt hard. TDC center and the engine in time will be as I decribed in my photos a few posts up.
Timing mark lined up on pulley and front cover. Intake cam gear at 2 o clock and exhaust at 10 o clock.
Piston #1 & #4 will be up, piston #2 & #3 will be down. Check with a screw driver.
Old Jan 29, 2014 | 07:25 AM
all of this is basic auto if you don't understand it take it to a shop take it to a shop
Old Jan 29, 2014 | 03:22 PM
josh6854's Avatar
Before installation, intake at 2 with blue link and exhaust at 10 with red link?
