Lsj wont start
Lsj wont start
I have a 2007 cobalt ss I just had the motor rebuilt it will crank and crank but will not start, no codes I checked timing and timing was dead nuts, fuel is there and spark plugs are sparking, when I try To start it and pull plugs there wet with gas the car will not start compression is 140 across the board...it's a fresh motor and help is appreciated!
If the plugs are wet they are probably screwed. Throw in some new ones and see what happens. I had starting issues in the winter crank and crank wouldn't start. Changes the plugs and started first try.
Remember every time you try to crank it it is pouring in fuel so let it sit a few minutes after each try or the fuel will start to puddle. Also if you have been trying and trying the fuel may have worked its way down between the rings and your oil may be screwed to. pull the dipstick and if it smells like gas you gotta do an oil change to.
Cylinder 1 to dead center everything's plugged in I will give new plugs a shot maybe under compression there not working? I figured 140 was okay for a fresh motor without rings being seated yet
