MAF sensor, limp mode, and much more!
Old Sep 18, 2013 | 10:02 PM
t racer's Avatar
Still at the dealer for the converter going on 2 weeks? but I looked for the pcv valve under the intake did not see it do you have to remove the foam under the intake or just remove the intake? To replace
Old Sep 18, 2013 | 10:13 PM
Sox-Fan's Avatar
Got Brakes?
Only the intake. It's actually IN the intake manifold.
Don't remove that foam. Conventional wisdom is that you'll get tons of false KR if you do.
Old Oct 21, 2013 | 09:52 PM
tommyk's Avatar
Originally Posted by bigjacksauto
Actually the tube before the turbo intake is designed for fresh air to enter the engine as part of the pcv system.
The pcv valve that I had replaced per the gm engineer is located in the intake manifold.
Seems it was not closing all the way under boost and letting oil back into the intake under boost.
Thanks to everyone here and other sites and some others that I need to get an OK from before listing there usernames and of course my dealership and mechanic
It is running great hopefully for good.
Do you happen to have that part # for that valve inside the intake manifold? I busted out my service manual but can't quite find much information about it... Also, since this car is my DD I can't quite start taking it apart until I have all the parts :\
Old Nov 6, 2013 | 12:14 PM
TurbaltSS_09's Avatar
Originally Posted by Sox-Fan
If you have the blue Bosch sensors you have the wrong o-rings in, and they are leaking pressure. That will 100% of the time give you a p0101. The ECM is getting measurements from the MAPs that make no sense compared to what it is being told by the MAF (which is after the MAF). Why? Because air is leaking by after the turbo. Replace them with the black o-rings that I linked.
Will this cause a P0100, P0102 & P0103? Same rough start, limp mode, bucking symptoms ect. also have a P0013 (exhaust cam actuator solenoid). I dont want to replace my MAF unless I have too. If it's just the o-rings then you sir are a god!
Old Nov 8, 2013 | 04:52 AM
bigjacksauto's Avatar
https://db.tt/cVj7k82g
Old Mar 12, 2016 | 06:34 PM
redman2357's Avatar
Does anyone know what the part number is and where I can buy the package valve in the intake mani. Been getting oI'll on my sensors also...thx
Old Mar 12, 2016 | 06:41 PM
redman2357's Avatar
Does anyone know what part number this pvc valve inside mani is, been having oil on map sensors for awhile now hopefully I can get this fixed tired of the limp modes, Cel code for p0106 etc... thx
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
