maf sensor problem need help asap
well as alot of you maybe know my lsj is turbo, and i got the car tuned yesterday and when i was tuning yesterday when i putting boost up,when i got up to like 27 psi the car started braking up about 5,500 rpm's and the check engine turns on and its code p0103 mass air flow high frequency? some people told me the maf is maxed out? anyone have any idea what it could do? maybe run a lnf maf if it could be done?
My MAF sensor needs to be unpluged and reset
the ECU unit every month or so. Engine light comes on for a while and goes away when I unplug and plug back in which resets the ECU. Have to do this sometimes a few times until it resets correctly.
made 454 on stock long block just arp bolts n cometic headgaskets n diamond racing pistons
I have pulled the connection at the MAF
Let the engine change sound a bit and plug back in. Sometimes I have to do it a few times then it will be good for a while and then repeat. Running 24 psi and about 350 plus hp. I don't know if that is part of the problem or the fact that I am running with a larger exhaust leak I haven't fixed.
bump really need some help :/
can i use a 08-09 cobalt ss/tc maf sensor
doesnt the MAF max out at 22.5 psi? because i am also LSJ turboed and if i go past 22.5 psi, my boost gauge resets to 0.. i dont know if thats because i have the LSJ boost gauge still or what lol but i remember somewhere saying that theres a limit of 22.5 psi.. and streetdreamz found a way around it.. he made a how to somewhere to change the MAF.
richard i was thinking about it more. you might have to put a piece of 3.5 inch pipe where the maf is. your starting to get where few lsj's have ever gone so there is no clear cut answer for this
Sl0wbaltSS
Nov 21, 2018 11:11 PM
