MAF sensor Question
Old Jun 12, 2010 | 06:45 AM
jhop16's Avatar
MAF sensor Question
I recently put together an intake for a 2.2L XFE, i cut my own hole in the pipe for the MAF sensor, but i could only secure it with 1 screw, it ran great for acouple trips , then started to die when i hit the gas, Note: car only has 7k miles on it.... anyways i put the stock intake box back on an put the MAF on that, and it runs fine now... my question is ... is it really that sensitive? or did i just do something wrong
Old Jun 12, 2010 | 08:01 AM
Coblasts's Avatar
You didnt have any codes.
There should of been a few if the car was dying because iof the maf I would think.
Put up a pic of the set up you had.
Did you have it in the right way ?
Old Jun 12, 2010 | 08:04 AM
jhop16's Avatar
what do you mean the right way? does it matter which side is facing which way? and no there was no codes... it started dying and sputtering so i got it home and swapped the intake back b4 i got an engine light
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
