misfire
Old May 7, 2007 | 03:43 AM
Georgekillsimports's Avatar
misfire
Hey everyone i got an 06 ss/sc and i put on the fujita intake, zzp header and downpipe along with the gmpp exhaust. well my issue is constant misfire in all 4 cylinders on an idle scan from hptuners. i changed out the plugs and i am still getting really bad misfire. my car was built on 05/06 so i have to get the time chain fixed do you think that will help?
Old May 8, 2007 | 12:21 AM
anybody?
Old May 9, 2007 | 08:53 PM
1SICKSS's Avatar
Im having the same kinda problem. I was told aftermarket intakes are notorious for improper MAF sensor placement and result in skewed air/fuel ratios and can cause lean conditions not necessarally missfire. is ur check engine light on? i just found out of that problem and im going to put my stock air box on and see if that helps.
Old May 10, 2007 | 09:48 PM
Krash^Fox's Avatar
I have an AEM intake in mine. I didn't notice any missfire until I put on My 3" catback two months later. But yeah I feel yeah
Old May 18, 2007 | 03:11 AM
update
well the problem was solved by the dealer i had a bad injector. it was stuck closed for some reason. i rescanned and got no misfire
Sean Cummings
Mar 9, 2018 12:26 AM
717ssbalt
Oct 2, 2015 04:01 PM
SStevie
Sep 21, 2015 11:37 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Fearedbynone
Sep 4, 2015 10:24 AM
