Please help weird vibration
Old May 15, 2007 | 12:57 PM
GMPD's Avatar
Im experiencing a weird vibration in my steering wheel on excellaration. My first guess is CV shafts but im not sure. I just lowered my car last week and im not sure if that would have anything to do with it. Any help would be greatly appriciated.
Old May 15, 2007 | 01:01 PM
06_SS_S/C's Avatar
Weird. I just lowered my car this weekend too, along with a Progress rear sway bar and I thought I noticed some kind of slight vibration when going from about 20-30 mph or so. I thought it might just be my imagination, but now that you say the same thing, I wonder what it might be.
Old May 15, 2007 | 01:07 PM
GMPD's Avatar
at first it seemed like it was just slightly noticable but as time goes on its worse. maybe the change in the driveline angle??? but i didnt do a extrem drop just fr.1.3 rr.1.5
Old May 15, 2007 | 01:24 PM
06_SS_S/C's Avatar
Ya, I used the Sportlines which is just 1/1.2 or so. But it is just at those lower speeds. Once I get above 30 or so I don't notice anythign.
Old May 15, 2007 | 04:08 PM
GMPD's Avatar
Anyone??? I really could use some help.
Old May 15, 2007 | 06:26 PM
DoubleClutchin_ION2's Avatar
alignment, steering rack, tire balanced properly,...
all these thing can affect it..
+ check all boots to make sure none ripped
Old May 15, 2007 | 06:58 PM
GMPD's Avatar
ALL checked out good. Im actually a technician and the first thing i would replace on a customer vehicle would be the cv shafts,but for some reasone i thought it might have something to do with the drive angle from lowering it. I was just wondering if anyone else has experinced this on there balts. ive lowered Lots of cars and never had this happen.
Old May 16, 2007 | 09:39 PM
eastcoastz's Avatar
I've got the same problem. Tires balanced and the front end is tight.
Old May 17, 2007 | 01:43 AM
WopOnTour's Avatar
Common occurance when lowering and correct CV angles are not maintained
Wop
Old May 17, 2007 | 08:52 AM
GMPD's Avatar
removed tenzos and no problems. I had my align specs within tollerance after the drop so im still not sure if i need new cv's or not.
Old May 17, 2007 | 11:17 PM
eastcoastz's Avatar
I've personally checked my alingment on our brand new Hunter rack twice since I've lowered the car. Just had to tweek front toe slightly.
Old May 17, 2007 | 11:37 PM
WopOnTour's Avatar
Too bad even the best alignment machines dont measure CV working angle or toe related "full travel" bump-steer before and after drop-spring replacement
Wop
Old May 18, 2007 | 12:24 PM
GMPD's Avatar
Did you toe it in or out? i guess i could just start messing with it some more. ive had the springs on and off 4 times this week. upside is i can have em done in about 10 minutes
Sl0wbaltSS
Nov 21, 2018 11:11 PM
chefhhr
Oct 26, 2015 10:36 PM
Tupp
Sep 30, 2015 08:18 PM
jcarroll53
Sep 24, 2015 07:43 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
