Misfire Cyl 4???
Old Oct 22, 2010 | 02:04 PM
bigblock2.4's Avatar
Misfire Cyl 4???
For the last month of so, my car (2006 2.4 auto) has had a random misfire. Always cylinder 4. It does it very randomly but you can definately feel it. The plug has always looked fine. I have replaced the twice just to check. I even swapped coils around and still is cylinder 4. Any ideas what else to check. Like I said, it only does it randomly and mostly at idle. Only code is P0304.
Thanks for any help
Old Oct 22, 2010 | 02:20 PM
recklessactn's Avatar
injector. run cleaner or seafoam through the gas tank. If that doesn't work go to the dealer.
Old Oct 22, 2010 | 04:17 PM
outta warranty....talk to a guy today that works for chevy that told me to check compression. That the valves on the 2.4 tend to go bad. I dont understand how a bad valve could make it misfire randomly. I figure it would happen all the time.
Any opinions?
Old Oct 24, 2010 | 02:55 AM
BlackCobaltsssc's Avatar
if there is no compression that cylinder will not fire causing it to miss. I really dont understand why GM is still staying with the stupid 2.4's there crap and they know it!!!!
Old Oct 27, 2010 | 12:48 PM
MyOtherSS's Avatar
I had the o-rings on the injector go bad on the #2 cylinder on my old cavalier and it was causing the misfire. I replaced coils, housing and plugs(needed em anyway) before i replaced the o-rings and it solved the problem. Might be worth it to just take a look.
Old Jan 10, 2011 | 04:08 PM
bump.....
Still having same problem... pulled plugs 3 and 4 out....look burnt. Had a brown ring around the base of the Porcelain. I didnt pull out 1 or 2....in a couple weeks, I am going to change my valve cover gasket...thinking about putting on a new intake gasket and clean the throttle body and add a new gasket there too. Some new fuel injector o-rings too....
Anyone tell me a way to check the injectors off the vehicle?
Turbo Johnny
Feb 21, 2019 09:41 AM
Sean Cummings
Mar 9, 2018 12:26 AM
717ssbalt
Oct 2, 2015 04:01 PM
TheSandMan
Sep 20, 2015 06:02 AM
