missfire count through the hood... ?
Old Aug 8, 2014 | 05:31 PM
reddragon72's Avatar
Anyone have any input.
2.9 60s with canned tune from ZZP.
All mods listed in sig.
Also note that I have pulled and cleaned the MAF twice. plugs are 2cool and .35 gap(came with kit from ZZP.
Old Aug 8, 2014 | 06:39 PM
CobaltSS 16's Avatar
Stock heat range is all you need for your setup. Maybe 1 step colder.
Old Aug 8, 2014 | 06:56 PM
mrbelvedere's Avatar
Get the car retuned and go with a 4644 ngk which is 1 heat range cooler you do not need 2
Old Aug 8, 2014 | 07:04 PM
TStone's Avatar
Idk how much I would rely on my cell phone app.... & if it's nothing "current" then i wouldn't worry about it. It could have been from before you retune or something.
Old Aug 8, 2014 | 08:16 PM
YelloEye's Avatar
Those history ones clear on a regular basis if they don't continue incrementing.
You can clear those by clearing a CEL, then you'll know if it's continuing. Pull an ignition coil plug while the car is idling, you'll get a misfire code, clear it.
Old Aug 9, 2014 | 07:20 PM
So the NGKs they sent are BKR7E... not sure what those are never looked it up it's just what they sent.
As I drive the current jumps up but clears after about 5 sec. I've seen 12 on 3 and 1 multiple times.
I have a CEL and cleared it and still seeing the numbers stacking up.
06noscobaltss
Jun 3, 2006 10:41 AM
90BerettaGTZ
Apr 4, 2006 02:57 PM
plyboy-illest
Jun 9, 2005 09:50 PM
