missfire at idle
Old Sep 7, 2007 | 05:23 PM
bl0wnbalt's Avatar
missfire at idle
for what reason would i be throwing a missfire code, only at idle
Old Sep 7, 2007 | 05:29 PM
SSdan's Avatar
Mods?
Old Sep 7, 2007 | 05:36 PM
bl0wnbalt's Avatar
custom tune, k&n cai, 42.5 injectors, 2.85 pully, ngk 1 step colder plugs, theres more mods but those are the only ones i can see causing me to missfire, ive been running this tune for over a month with no problems so i dont think its that, i first thought maybe im running rich at idle but why now, maybe my plugs are set at the wrong gap, there a month old too there set at 35 hundredths, maybe a coil pack?
Old Sep 7, 2007 | 05:39 PM
SSdan's Avatar
Recheck the plugs, something in the tune i'd say.
Old Sep 7, 2007 | 05:44 PM
bl0wnbalt's Avatar
lets say it is my spark plugs, wouldnt i be getting missfire at high rpms instead of idle?
Old Sep 7, 2007 | 05:45 PM
SSdan's Avatar
Yea, I think it would be misfiring or studdering during acceleration. Now that I think of it, maybe it is sensing something in the tune and throwing the code without a true misfire.
Get the tune checked.
Old Sep 7, 2007 | 05:48 PM
bl0wnbalt's Avatar
yeah, cause the car runs fine, no stuttering, has a smoothe idle, doesnt jump up and down at idle like it did with the stock tune
Old Sep 7, 2007 | 05:49 PM
SSdan's Avatar
Is it random cylinder or multiple?
Old Sep 7, 2007 | 05:51 PM
TheBaltSS/SC's Avatar
I would say the pulgs or the tune. I would pull the plugs out and check them to see how they look.
Old Sep 7, 2007 | 05:53 PM
Sunburst_SS's Avatar
check for vacuum leaks....
Old Sep 7, 2007 | 05:56 PM
bl0wnbalt's Avatar
checked for vacuum leaks, none, im gonna pull the plugs tonight, our plugs are annoying to pull but whatever, i got a friend whos a chevy tech thats gonna do scan with a tech2 to tell me what exactly is goin on
Old Sep 7, 2007 | 06:00 PM
sugardaddy2885's Avatar
I was throwing a misfire code last week. My coil pack went bad, had to get it replaced.
Old Sep 7, 2007 | 08:20 PM
bl0wnbalt's Avatar
well i cant find my t-30 bit so i cant get the spark plug cover off to check the plugs, i got a scan at autozone and im actually throwin 2 codes, P0300(missfire) and P0315(crank sensor), is it possible that my missfire will cause a bad crank sensor reading, or has my crank sensor gone bad and its causing me to missfire?
Old Sep 7, 2007 | 09:53 PM
a bad crank sensor will cause misfires.....extended crank...and even a no start situation. I'd take it in and get it looked at
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
n20saturn
Sep 21, 2015 01:50 AM
