Missfiring... got p0300 and p1182
the 1182 code is for the SCIP sensor......do some quick checks, make sure the intake tubing is all connected good, no leaks....also check for vac. leaks. Make sure the seal around the scip sensor isn't leaking, etc.
To see if the coils were bad.
I did the oil change a week ago...
yes, but a vac. leak or something of that nature would cause a misfire.....and an air leak between the MAF and the TB would cause the p1182, so it could all be the same issue.
Do you have something to monitor which cylinder is misfiring??? Cause unless you do you won't be able to use that method rule out the coil either.
1182 is a SCIP pressure check. It's also likely the SCIP itself is dirty or leaking air into the SC. Unbolt it and spray it with brake cleaner. Fixed my P1182 last week.
M88ArRamadi
10-29-2007 11:27 PM
