moaning/whining noise while autocrossing/ vid
Old Mar 13, 2012 | 01:11 PM
Wes11's Avatar
It seems to occur while accelerating hard out of turns. LSD, tires slipping on the rim, brakes? I don't know, but it only happens on R comps. I thought it was just the tires rubbing on something, but after watching the vid I don't think that's the case and I couldn't find any evidence of it.
2012 dixie tour Sunday - YouTube
Old Mar 13, 2012 | 01:31 PM
SS_carnatic's Avatar
What year is your car? Do you have stability control?
Could be stability control applying braking force to inside wheel to keep you from spinning? Whenever my stability kicks in over the winter it sounds like the ABS kicking in although its braking a single wheel.
If it was the tires you would think you would here the sound as soon as the car dives into a corner, the sound seems to be coming mid corner most times.
@ 1:04 you can also hear the moan speed up with the car so IDK just a thought.
Old Mar 13, 2012 | 02:22 PM
Wes11's Avatar
Should have put that in the op, but it's an 09.' I turn the ESC off, but your post makes me wander if it still has some authority...
Old Mar 13, 2012 | 09:46 PM
Balt_and_Vette's Avatar
Could it be a bad bearing?
Or maybe your shafts if your lowered.
Last edited by Balt_and_Vette; Mar 13, 2012 at 09:46 PM. Reason: Automerged Doublepost
Old Mar 15, 2012 | 11:18 PM
PenguinPIE's Avatar
I read that our LSD makes a low whining noise
I get that noise when I autocross in rain
skip to 1:27 for that noise
UBC SCC 2011 Slush Series 2 Autocross - YouTube
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
