Need help asap!!!!
Old Mar 22, 2011 | 01:14 AM
DiabeticKripple's Avatar
Thumbs down Need help asap!!!!
i took my switches out of my door bezels today to paint the bezels, and i decided while they were out, i would make the bulbs glow red. so i took some tail light tape and taped them up and put them back together. when i put my drivers side pw switch in, my window instantly rolled down, and would not go back up. i took apart the switch about 20 times and it still wouldn't go up. i had to leave so i left it as it was. i came back about 2 hours later and pulled it apart once more, put it back together and the window went up! what went wrong? i didnt **** anything up when i removed or installed them. well i now have a new problem.................... the dash wont light up at night. the switches aren't lit up, cluster, radio, and hvac. anything that is supposed to light up isn't. my headlights wont even switch from auto, to off or anything. my electrical is fucked! did i blow a fuse or something? i have no idea what to do other than leave it for now.
Old Mar 22, 2011 | 01:25 AM
CruzinYellow's Avatar
You may have had shorted some wires by accident if you removed the switches without the battery disconnected. There still might be a problem with the wires going to the window switch. Check for spots where bare metal is showing and wires might be close to touching. It definitely sounds as if you may have blew the fuse for the interior lights. I have an 07 SS and in my manual it only shows having 1 fuse for all the interior lights. Good luck. It's more than likely an easy fix.
Old Mar 22, 2011 | 01:27 AM
i checked the wires, they aren't shorting out. is the fuse under the hood? or in the passenger kick panel?
Old Mar 22, 2011 | 02:16 AM
Bump for help
Old Mar 22, 2011 | 10:25 AM
Old Mar 22, 2011 | 11:35 AM
Bump for steve
Old Mar 22, 2011 | 12:39 PM
outtamymind's Avatar
checked your fuses in the BCM panel as it does sound like something shorted out while you were working on it. in regards to the switch, chances are you didn't put the switch back together properly as they are just a rocker switch for the windows.
but check all your fuses in the kickpanel and get back to me.
Old Mar 22, 2011 | 12:45 PM
I only had the bottom out, I never took the rocker switches off. I'll check them after school
Old Mar 22, 2011 | 12:55 PM
you still would have had to pull them apart to put the tape in, which means logically when you put it back together it was putting pressure on the down side of the switch.
Old Mar 22, 2011 | 01:14 PM
07SSYellow's Avatar
Resident Post Whore/Troll
check the kick panel, i know the big pink fuse is for the power windows, but not sure about the others, hope u get it fixed bro
Old Mar 22, 2011 | 01:25 PM
On that one I put the tape on the bulb itself. The bulb is on the circuit board. There was no tape to make the switch go down
Old Mar 22, 2011 | 01:27 PM
the tape wouldn't happen to be metallic would it
Old Mar 22, 2011 | 01:37 PM
Nope plastic tail light tape
Old Mar 22, 2011 | 01:42 PM
ya check your fuses and think if there's anything else you did like cut a wire or anything like that. can't help ya if you leave out information
Old Mar 22, 2011 | 01:48 PM
Never touched the wires. I've taken the switch out like 4 times no issue until now
Old Mar 22, 2011 | 03:59 PM
I called soundjunky and he said to check the fuses and if they are fine then it could be the bcm. I hope it's not the bcm and just a fuse
Old Mar 22, 2011 | 04:10 PM
i told you to check the fuse's a long time ago dude lol
Old Mar 22, 2011 | 04:29 PM
07blackg5's Avatar
Slobodan Milošević
like i said... replace the dash light batteries. 4 D cells
Old Mar 22, 2011 | 07:17 PM
i know you did and i was going to steve, i was just saying what jon told me to do. i pulled EVERY fuse in that box to see if any were broken. none were theres something else wrong. i believe it is stuck on day lights as the radio and DIC are bright.
Old Mar 22, 2011 | 07:24 PM
did you test them with a test light, just because they don't look broken doesn't mean they aren't
Old Mar 22, 2011 | 07:25 PM
i did not do that i visually inspected them at southcenters parking lot
Old Mar 22, 2011 | 07:30 PM
ya test with a test light and confirm, if one is blown it will not light up with the switch turned on.
Old Mar 22, 2011 | 07:32 PM
i guess ill have to buy one, but im leaving tomorrow so it will have to wait until i get back
Old Mar 22, 2011 | 07:36 PM
ya do all your exterior lights work. also try unplugging your switches and see if the lights return to normal.
Old Mar 22, 2011 | 07:38 PM
im scared to pull the drivers pw switch lol in case it rolls down again. but headlights and tail lights work, one reverse light is burnt out (im thinking from my crash that was on purpose)
