need help diagnosing!!!
Old Feb 24, 2013 | 10:08 PM
1LowLS's Avatar
All of a sudden my cars running super lean only when I get into boost.I've put a new o2 in it,no exhaust leaks,boost and vacuum has not been affected.new fuel filter,fuel pressure is at 60 psi running.can the maf read wrong with out throwing a code? What about the back o2? I'm at a loss.
Old Feb 24, 2013 | 10:22 PM
1LowLS's Avatar
Old Feb 24, 2013 | 10:42 PM
1LowLS's Avatar
Old Feb 24, 2013 | 11:04 PM
klutch814's Avatar
The back o2 doesnt matter. i dont have one and its tuned out thats how i know. have you sent a log to vince to see what he says? bad batch a gas? vids? lol
Old Feb 24, 2013 | 11:09 PM
turbosmart4's Avatar
Maybe u have a bad evap purge solenoid?
Also clean the tb
Last edited by turbosmart4; Feb 24, 2013 at 11:09 PM. Reason: Automerged Doublepost
Old Feb 24, 2013 | 11:13 PM
1LowLS's Avatar
Happened on the same tank of gas.I have not tried the solenoid although I thought about it.my back o2 isn't tuned out.just p0420 is disabled.
Old Feb 24, 2013 | 11:16 PM
1LowLS's Avatar
Tb was just cleaned
Old Feb 24, 2013 | 11:20 PM
Test the solenoid by removing it and blowing on it. If u. Can get air to flow out through its other end then its bad.
Old Feb 24, 2013 | 11:22 PM
Also check the oil dipstick. Believe it or not those things trigger lean code when not sitting properly , and know it from experience lol
Old Feb 24, 2013 | 11:23 PM
1LowLS's Avatar
I have a spare in my trunk.ill check both though.hopefully that's it.thanx for the input.
Old Feb 24, 2013 | 11:25 PM
Another thing u might want to check is for boost leaks, or exhaust leaks . I had a cracked exhaust manifold giving me lean code problems a month ago..
Old Feb 24, 2013 | 11:27 PM
People say u can spray carb cleaner on vaccum lines and intake mani to see if there is a leak. If there is a leak the car will accelerate a little. Good luck man
Old Feb 24, 2013 | 11:57 PM
1LowLS's Avatar
There are no vacuum/boost leaks.evap solenoid is fine...no lean code.wideband is reading really lean and would cut out from being so lean
Old Feb 25, 2013 | 12:55 PM
1LowLS's Avatar
Any more ideas?
Old Feb 25, 2013 | 01:06 PM
rivaladore's Avatar
Maybe your wideband isnt reading properly
Old Feb 25, 2013 | 01:12 PM
1LowLS's Avatar
I wish it was that simple but when it shows lean it falls on it face,so its accurate.
Old Feb 25, 2013 | 01:52 PM
Replace the solenoid and post results.
Old Feb 25, 2013 | 02:45 PM
1LowLS's Avatar
I disconnected it and same thing.it holds vacuum/ boost.ill change it any way but I'm not expecting it to be bad.
Old Feb 27, 2013 | 12:24 AM
1LowLS's Avatar
Have yet to figure it out.triple checked for vacuum leaks.guess its time to throw parts at it.I'm going to try maf and map 1st.if not it then oh well then it has new sensors.just makes no sense.I deleted the evap for a couple pulls and no change.
Old Feb 27, 2013 | 06:36 AM
Pleass's Avatar
Injector issue?
Old Feb 27, 2013 | 09:28 AM
1LowLS's Avatar
I would think if it was injector,it would do it even cruising.I don't know.I'm going to go over everything again to make sure I didn't miss anything.
Solaris99
28
Mar 15, 2017 01:22 PM
ATOMbomb
Sep 11, 2015 10:48 AM
Bluelightning
Aug 31, 2015 12:17 PM
G85 SS
Apr 7, 2008 08:36 PM
