need help maf
Old Sep 12, 2008 | 08:49 PM
Bl4des's Avatar
need help maf
o cleaned my maf and now my car does not run right it threw a p0102 and is running rich sometimes when just cruising what happened
Old Sep 12, 2008 | 08:54 PM
wardzach2007's Avatar
Why again did you clean it out?
Old Sep 12, 2008 | 08:55 PM
Bl4des's Avatar
i felt like it
Old Sep 12, 2008 | 08:56 PM
Originally Posted by Bl4des
i felt like it
Good enough for me.
outtamymind's Avatar
did you put the maf back in properly and what did you use to clean it and did you let it dry before you put it back in?
Old Sep 12, 2008 | 09:37 PM
Bl4des's Avatar
yeah i put it back in right i bought maf sensor cleaner and i think it was completely dry but i didnt drive the car until like 3 hours after i put it back in
i dont get it
Old Sep 12, 2008 | 09:51 PM
hmm stupid question i know, but have to ask. did you handle it with car as those things are quite sensitive to drops and sudden sharp movements.
Bl4des's Avatar
anyone
Old Sep 13, 2008 | 12:51 AM
highrider43's Avatar
You may have used the wrong type of cleaner......a lot of maf cleaners are NOT plastic safe and should not be used on our cars......The maf wires as you could call them on the inside of the sensor have a clear coat of sorts on them.....the wrong type of cleaner will destroy this clear coat and basically ruin the maf sensor.......i know here in canada a standard can of maf cleaner goes for about $8-$9.......the plastic safe stuff is around $24 a can so that might tell you if you have used the wrong cleaner.......just my 2 cents........Later
Old Sep 13, 2008 | 12:16 PM
Bl4des's Avatar
how much is a maf i think mine my be messed up
where can i get a maf sensor
Old Sep 13, 2008 | 02:22 PM
you can get a maf from the dealer but from what i remember they are a few hundred bucks. i work at a dealer by the way
Old Sep 13, 2008 | 02:23 PM
Bl4des's Avatar
i just ordered 1 for 65
Old Sep 13, 2008 | 02:24 PM
where from? oh and i looked up what the p0102 code is and its a dtc for the maf sensor circuit low frequency so ya something got messed up when you cleaned your maf.
Old Sep 13, 2008 | 04:07 PM
Bl4des's Avatar
i ordered it from an auto parts store by me
Old Sep 13, 2008 | 06:29 PM
nice.
Old Aug 14, 2009 | 03:56 PM
SqueakA1C07SS's Avatar
i have the same code the p0102 and a p0103 code, but i didnt get those codes until i installed my HID's any one got any suggestions.
Old Aug 15, 2009 | 09:30 AM
Coblasts's Avatar
I would say you buggered up the wiring some how.
Check all your connections you made and make sure they are good.
If you spliced into any wire which ones and what color might help to figure out what is going on.
Old Aug 25, 2009 | 05:43 PM
i fixed it, it was the little sensor on the actuall SC it had some residue on it.
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Superslowbaltt
Sep 22, 2015 10:24 AM
Superslowbaltt
Sep 21, 2015 07:50 PM
