need help throwing exhst code
Old Oct 6, 2008 | 12:10 PM
chevysssc's Avatar
Exclamation need help throwing exhst code
i just changed my header and now its throwing exhst code. not sure whats wrong i disconected the battery for 15min to reset and stil throws codes. its a cobalt addiction header to a 3 inch zzp down pipe into 2.5 exhst. need help thanks
Old Oct 6, 2008 | 12:15 PM
brickerenator's Avatar
welcome to the world of modified cars
you will most likely have to get it tuned out
Last edited by brickerenator; Oct 6, 2008 at 12:15 PM. Reason: Automerged Doublepost
Old Oct 6, 2008 | 12:16 PM
chevysssc's Avatar
thanks
Old Oct 6, 2008 | 05:06 PM
Dainslaif's Avatar
It would help if you actually posted the code. It's either lean condition or Rear O2 cat efficiency. If it's the first, get a tune, if it's the later, you can either tune the code out, or trick it with a drilled out spark plug fouler. Been running mine catless with the fouler since Saturday and no codes. Can pick them up for 3 bucks at any auto parts store, look for Help! brand PN 42009. Drill it with a 7/16" or 1/2" bit, screw it on and put that into your pipe.
Old Oct 6, 2008 | 05:08 PM
ikeryder13's Avatar
get a CEL eliminator....
Old Oct 7, 2008 | 07:15 PM
chevysssc's Avatar
i left the battery disconnected over night and have had no light for 2 days might get tuned on the 18th at tune time
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
