need some cel help
need some cel help
so i just got a new motor in my car with .30 pistons ported head ferrera valve train balance shaft delete mild port on mani. so the car is showing that it is having early detonation in the third cylinder. stock supercharger stock tune stock injectors but 1 step colder plugs and 2.8 pulley. the cel flashes when the car starts to spudder then goes away then comes back on. what do you guys think
ok update my car is throwing a misfire code in cyl 3. i switched coil packs switched plugs even switched injectors. the car just feels like it is spuddering whenever i hit boost. im also boosting at 22? does anyone think this is my ignition coil
