need some cel help
Old Nov 27, 2009 | 11:32 PM
slwblt's Avatar
need some cel help
so i just got a new motor in my car with .30 pistons ported head ferrera valve train balance shaft delete mild port on mani. so the car is showing that it is having early detonation in the third cylinder. stock supercharger stock tune stock injectors but 1 step colder plugs and 2.8 pulley. the cel flashes when the car starts to spudder then goes away then comes back on. what do you guys think
Old Nov 27, 2009 | 11:35 PM
bmb17's Avatar
You shouldn't have a smaller pulley with out bigger injectors. No sure if thats causing your problem.
Old Nov 27, 2009 | 11:39 PM
slwblt's Avatar
ya i know that im just tryin to figure out somethin
Old Nov 27, 2009 | 11:40 PM
MikeyB's Avatar
2.8 pulley on stock injectors?!?!
thats pushing it on GM 42's
Upgrade injectors asap and get a tune and go from there.
Old Nov 28, 2009 | 10:21 PM
slwblt's Avatar
ok update my car is throwing a misfire code in cyl 3. i switched coil packs switched plugs even switched injectors. the car just feels like it is spuddering whenever i hit boost. im also boosting at 22? does anyone think this is my ignition coil
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
