Need wiring diagrams asap!!!
Old Mar 29, 2012 | 08:32 PM
Jdam8139's Avatar
Long story short, I decided to splice my wideband in with my A/C press sensor so I could log AFR....and now the car won't start. The start energizes and the accessories have power, but the engine won't fire up on its own.
Right now I'm thinking it could just be a blown ignition fuse somehow, but its dark so I can't really check until tomorrow morning. In the meantime I need help from ANYONE WHO HAS OR HAS ACCESS TO A WIRING DIAGRAM SHOWING PCM INPUTS (preferably including wire colors). I'm 90% sure I cut the right wire, but just to be positive I want to confirm with a diagram. Or, if anyone knows if there are any other wires that are inputs to the PCM that are red with black stripes.
btw its a 2006 LSJ
Thanks!!
Old Mar 29, 2012 | 10:51 PM
redcobalt07's Avatar
A wideband and AC sensor go together why?
Old Mar 30, 2012 | 02:17 PM
Jdam8139's Avatar
A/C Pressure sensor outputs a 0-5v signal to the PCM, and so does the wideband. So if you use a switch and relay setup to switch between A/C Pressure input and Wideband input to the PCM, you can use HPTuners to log AFR while your PCM thinks its A/C Pressure.
In HPTuners, you use the A/C Pressure (volts) PID multiplied by a correction factor to convert the voltage to AFR. You do this by comparing the displayed AFR on the wideband and the voltage output from the wideband on the A/C Pressure pin. Divide AFR by Volts and voila, you can log AFR without an EIO for HPTuners.
Here's a How-To from the Corvette forums that I adapted to the cobalt
Connecting Wideband via A/C Sensor
BTW everything is fixed now, the car runs fine and its logging AFR just like it should be. I made a really stupid mistake
Old Mar 30, 2012 | 02:24 PM
tpete763's Avatar
Explain this mistake lol
Old Mar 30, 2012 | 07:50 PM
Jdam8139's Avatar
The wire coming from the A/C Sensor is red with a black stripe, but I figured it would be easier to wire if i cut the wire closer to the PCM rather than at the sensor. Little did I know, there are a couple PINK+black wires that control something to do with ignition. So after deciding that the wire had just faded to pink rather than red, I cut it and wired it to my relay, then was surprised to find that the car wouldn't fire on its own.
I reconnected the wires and spliced into the right wire and everything is working great.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
