Bad cv axle? Help please
Old Mar 28, 2012 | 04:08 PM
bluedream06's Avatar
I have a clunking noise coming from under the passenger floorboard When I hit bumps in the road, I just replaced end links with moog links. The klunk seems to get worse the more I drive. I have replaced this cv before with a remanufactured cv. Do you think my cv is. Going bad again? I went ahead and ordered a brand new cv. It will be here tomorrow. Thanks guys
Old Mar 28, 2012 | 07:04 PM
MyOtherSS's Avatar
Did the noise go away after you replaced the axle the first time? I read that it can be the sway bar bushings causing the noise, i replaced my endlinks as well and the noise is still there but only if i hammer something.
Old Mar 28, 2012 | 07:20 PM
DaBuzzard's Avatar
Could also be control arm bushings (the factory ones are pretty wimpy), ball joints, tie rod ends, hell, it could even be the top strut bearing.
Get it in the air and check it out before you spend time and money replacing stuff that isn't causing the problem.
Old Mar 28, 2012 | 07:32 PM
Balt_and_Vette's Avatar
This^^^^
Old Mar 28, 2012 | 07:33 PM
K-Train04RL's Avatar
My money is on the strut mount or the rear control arm bushing
Old Mar 30, 2012 | 10:40 PM
Mechanic says its my driver side strut mount, and the the noise is traveling through my suspension over to the passenger... I ordered two moog mounts, replacing both just in case. Thanks for the replys everyone!
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
ernnyyes
Oct 2, 2015 05:16 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Iceberg
Sep 29, 2015 12:33 PM
