No battery power to anything 08 LNF
Old Feb 11, 2016 | 11:11 PM
jcalvin1126's Avatar
Hello,
I just did a major overhaul on my vehicle. not I didnt really mess with anything electrical outside of popping off the fuse carrier to remove the transmission. After getting it all back together. I go to put the battery back in and I have no lights no nothing. I believe I heard the door chime but nothing after. Research suggest looking into the BCM which I am going to do after leaving this. But in case its not that any suggestions??
Old Feb 11, 2016 | 11:26 PM
Maybe you forgot a ground?
Old Feb 11, 2016 | 11:32 PM
I never touched a ground though
Old Feb 11, 2016 | 11:51 PM
So looked through all the BCM and the fuse box within the engine bay. Still nothing, no fuse blown no nothing. I guess I will hav to look for a misplaced ground. However, I never touched one that I know of... I ******* hate this 5 days of work gone to **** because of some electrical problem.
Old Feb 12, 2016 | 12:20 AM
tuned08ss's Avatar
Did u test the battery? Where did it sit for the 5 days it was out of the car?
Old Feb 12, 2016 | 12:58 AM
cobaltss#01's Avatar
the fuse by the battery maybe?
Old Feb 12, 2016 | 10:33 AM
exninja's Avatar
It's possible you shorted something unknowingly and blew the fuse. Even if you removed the battery cable when you started (I really really hope you did that) it doesn't hurt to check.
Old Feb 12, 2016 | 10:36 AM
exninja's Avatar
Also, I'm pretty sure you'd have had to remove at least one ground to remove the transmission.
Old Feb 12, 2016 | 11:11 AM
That's what I'm thinking ^ haven't removed my transmission to be of more help of where that ground would be tho
Old Feb 12, 2016 | 11:33 AM
heeter_33's Avatar
This. If you stored the battery on cold concrete it could be dead. Heck, even if it was in the car it could be dead.
RedLined's Avatar
Don't know about the lnf but the lsj has a 30 jcase fuse for power. Also if you have a dmm or test light you should check to see if you've got power to the fuse box to rule that out.
Old Feb 12, 2016 | 11:37 AM
RedLined's Avatar
This was true of old batteries from before our time. Ive had brand new batteries sit on the floor for more than a few days without issues.
Old Feb 12, 2016 | 01:50 PM
cluelessk's Avatar
Pretty sure it's not recommended. I'm not saying you won't get away with it but an older weak battery might not be.
Old Feb 12, 2016 | 03:14 PM
exninja's Avatar
My car sat at the dealership for 2-3 weeks and that killed the battery. Completely dead. Jerks.
Old Feb 12, 2016 | 04:12 PM
cluelessk's Avatar
Work in a body shop. It's amazing how poor some batteries are. 30 mins with the door open and the car won't start.
AKillEaze
Feb 2, 2016 07:59 PM
coltonjohnbutler
Jan 31, 2016 11:13 PM
jcalvin1126
Jan 29, 2016 03:07 AM
wesg631
Jan 27, 2016 03:56 PM
matthud
Jan 17, 2016 01:01 AM
