No boost, codes
No boost, codes
P0101 - powertrain mass or volume air flow curcuit range/ performance problem
p2270 - powertrain 02 sensor signal stuck lean bank1 sensor 2
p2178 - powertrain system too rich off idle bank1
after a few pulls, i get no boost and these codes pop. I was thinking boost leak but i'm not sure. 2009 ss with intake, dp, trifecta.
Codes:
P0036 - heater control circuit bank 1 sensor 2
P2178 - MAF Lean to rich
P0101 - Dirty MAF
But I started to lose power and boost on way home after a partial WOT in 2nd gear then the closer I got to home the more I had to just baby it back no boost building up..
2010 cobalt ss/tc 28k miles
ZZP catless DP, K&N SRI, Inject upperCP, ForgedBPV, TWM short throw, Trifecta tuned..
My plan is to clean MAF, Check for boost leaks get HP tuned. Let me know how everything comes out for you.
Air leak test resulted in air pouring out of my intercooler. I took the bumper off and there was about a 10" crack on the passenger side of the intercooler. It was on the the front side so i couldn't see the crack until i took the bumper off.
Finally got to mine this evening been sitting in garage started to build boost tester while buddy was removing bumper and sure enough Same Exact thing 10-12" split passenger side calling around tomorrow Really want a ZZP intercooler says out of stock but you can buy the kit that has same intercooler... So calling them first thing in AM and if they say no the MXP or someone else overnight and fix hopefully friday pending the overnight shipping... ZZP is MI and I'm IN so would be very nice if they'll work with me...
This summer heat is cracking a ton of intercoolers. If you think about pushing 20 lbs of hot ass air through plastic its bound to happen when conditions are just right.
OrangeCoba
Sep 25, 2015 06:06 PM
