No Fan Operation on 1-4
Old Nov 30, 2010 | 02:30 PM
lukskywalker's Avatar
Ok,
This is a weird question and I checked the forums and didn't see anything with this issue but last night I noticed that my heater( blower switch) doesn't work from 1-4, but works on 5(the max). I checked the fuses and all seems fine.
Has anyone else had this issue, someone told me it can be a relay..
Please advise.
jsscooby's Avatar
probably the resistor
Old Nov 30, 2010 | 04:21 PM
The resistor in where. the motor, switch.. How do I test?
Old Nov 30, 2010 | 04:48 PM
reaper89's Avatar
blower motor resistor=sits in the blower (air blower). i had to change it on my 01 malibu before.
Old Nov 30, 2010 | 05:35 PM
LS6Rally's Avatar
its under the dash, pass side. right next to the blower itselft. on my cavy it was held in with 2 torx screws. im not sure on the Balts, but its typically simple to replace. the resistor for my cavy was like $33
Old Dec 7, 2010 | 05:05 PM
ok, called every autopart store here in iowa and no one has them in stock except autozone for 52.00. Bought it with a lifetime warranty. went home and replaced it and walla, it was fixed... 2 days later dame resistor gave way again.. Is this just because its a bad resistor or is somethg else making it go.
Old Nov 1, 2011 | 11:30 PM
bratboy90's Avatar
It's an issue with our cars. GM has some sort of bad ground somewhere, good thing you go the lifetime
Sean Cummings
Jan 8, 2020 10:17 AM
littless
Jan 18, 2006 10:03 AM
JonyyB
Mar 8, 2005 10:59 PM
JonyyB
Feb 21, 2005 11:13 AM
