No Start!
Old Mar 25, 2012 | 09:21 PM
SteveInMs's Avatar
No Start! Now Updated w/Culprit!
Haven't posted in a while Car's been great for almost 100K, but now, out of nowhere, it turns over but nothing else. It was running fire the night before.
'07 LT 2.2 manual, no mods
I got a code reader, no codes.
50 lbs. at the fuel rail
All fuses good
I pulled a plug, it's getting fire.
Replaced fuel filter
Replaced the gas cap (what the hck)
Replaced crank sensor
I put a shot of gas in one cylinder and it tries to start, so I'm thinking the injectors aren't firing.
I've ordered a cam sensor. If that's not it, I'm out of ideas and it's to the dealer she goes.
Anyone with any ideas or advice would be greatly appreciated!
steve
Old Mar 25, 2012 | 10:38 PM
bluebalt07's Avatar
Pull the injectors out and crank it to see if they are firing. Just put a rag or something over them so you don't make a mess. If not pull them out of the rail and see if they are clogged with something.
Old Mar 25, 2012 | 10:44 PM
bluebalt07's Avatar
Also 50 psi may be just low enough to not let the injectors fire. Just finished working on my girlfriend's s10 having fuel pump issues and it is supposed to have 60 psi in the feed line. Anything lower than around 55 and the injectors wouldn't fire. If that's the case, the fuel pump could be getting weak
Old Mar 25, 2012 | 11:08 PM
conerboner's Avatar
how's the battery and alternator?
Old Mar 25, 2012 | 11:13 PM
SteveInMs's Avatar
Both good
Full tank of gas too
What's the spc'd fuel pressure supposed to be for the Cobalt, anyone know?
okay, I'll do that, thanks
Old Mar 25, 2012 | 11:58 PM
bluebalt07's Avatar
Best I could find for the fuel pressure was between 55 and 65 with a quick google search
Old Mar 26, 2012 | 12:14 AM
SteveInMs's Avatar
That could be a problem too.... lookout bank account
Old Mar 28, 2012 | 01:13 PM
SteveInMs's Avatar
Just got the call from the dealer. 12V main feed to injectors was rubbing on AC hardline, grounding out.
Out the door for $194.00 plus tax.
Sounds expensive for just diagnostic and labor, but you don't know how relieved I am!
Whew
Old Mar 28, 2012 | 01:32 PM
cobaltguy889's Avatar
pull a spark plug and ground it to see if its getting spark. A no start could be big or small. check the three components. spark, fuel and air. which ever one its not getting follow. could be crank sensor, but idk. you'll have to investigate some more.
Old Mar 28, 2012 | 01:43 PM
kxrida2000's Avatar
i wanna say 53 but it has been awhile
Old Mar 28, 2012 | 03:04 PM
Chevrolet Cust Svc's Avatar
Whew
I'm glad to hear that you've been able to get the issue diagnosed and repaired!
Everything is running okay?
Sarah
GM Customer Service
Old Mar 28, 2012 | 09:15 PM
SteveInMs's Avatar
Sarah
GM Customer Service
Only drove it a few miles but so far so good. dealer personnel were great.
Preston Hood
Old Mar 29, 2012 | 08:55 AM
Preston Hood
Great!
Hoping it won't, but if anything comes up please don't hesitate to get in touch with me on the forum.
Best,
Sarah
GM Customer Service
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
