Not enough boost!
Old Jul 26, 2015 | 06:51 PM
volsfan92's Avatar
Not enough boost!
So I hooked up a new mechanical guage and it's only hitting 14-15 psi.. On the stock guage I was getting 17-18psi.. I tapped into the line coming from top of mani for boost.. Pretty sure I have a vacuum leak around the manifold gasket.. Will this cause low boost readout on the new gauge?
Old Jul 26, 2015 | 07:43 PM
Sharkey's Avatar
what pulley are you running?
Old Jul 26, 2015 | 07:56 PM
Sl0wbaltSS's Avatar
Or maybe they both read differently.
Old Jul 26, 2015 | 08:02 PM
volsfan92's Avatar
It's a 2.6 and it doesn't seem like it should be that far off
Old Jul 26, 2015 | 08:48 PM
volsfan92's Avatar
Could it be that the mechanical is more accurate?
Old Jul 27, 2015 | 12:40 AM
SSfamilywagon's Avatar
14-15 psi is really low on a 2.6 unless you'd have ported head ,cams and free flowing exhaust.
I'd double check your connection at the source and the back of gauge itself.
Old Jul 27, 2015 | 01:31 AM
Sharkey's Avatar
what brand of gauge is it?
Old Jul 27, 2015 | 12:02 PM
mrbelvedere's Avatar
air temp and altitude can be part of it bad bypass actuator also
Old Jul 27, 2015 | 12:49 PM
volsfan92's Avatar
I've checked all the lines.. I bought some good line instead of the clear **** and it's the glowshift gauge I've got friends that use it with no issues
Old Jul 27, 2015 | 05:02 PM
If you trust the gauge and your install then you need to check your by pass valve. Probably not closing all the way and bleeding boost
Old Jul 27, 2015 | 11:11 PM
volsfan92's Avatar
Thats the black thing on top of sc correct?? Also how could I check it
Old Jul 28, 2015 | 12:41 PM
volsfan92's Avatar
The valve moves easily on the bypass interceptor reads 16-17 on manifold psi
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
