Now I scared
Now I scared
Second time this happened. Probably 5 day apart, both in warmer weather than what we been having up in northwestern Ontario.
Check engine light comes on, power steering arrears on the dash. And this time the transmission shifted like I was 6 years old driving a standard... My cars automatic.. Horrible shifts, jumping, flutter, bogging
U2100 is the code
Im looking over the car now for broken or sketchy wires, as this is not my first electrical issue ive had with this car . ( speed sensor got ripped out last winter, along with loss of break lights ) all of which I fixrd
Google hasn't been much help....
U2100 is the code
U2100- Controller Area Network (CAN) Bus Communication -BCM, EBCM, IPC, PCM, PSCM, Radio, SDM,VCIM
if no one helps ill try to get you more info tomorrow morning
Ok so all this can stuff is located near the glove box right? That other fuse pannel that's there? This is a good thing if so I think. I lost that plastic cover piece for months , had wet salty feet all over that area for awhile. And I went through a car wash earlier today ( I get a trickle of water that comes in begind the glove box, it's small I never worried about it, rain doesn't come in just high pressure water ) I'll inspect the area ASAP !
You see what hes doing right? He's measuring resistance across the canbus network, you have to have the multimeter probes in the diagnostic port in the terminals he mentioned in vid 1. Then check the resistance, and then wiggle connectors for intermittent connections.
