OBD II code B2AAA
I thought all B codes were non powertrain codes.
Maybe the OBD2 sensor the OP has is not able to fully pick it up and just gives B2AAA
Anyway heres a link to all the B codes hope it helps
(I didn't want to post them all, its along list)
http://www.obd-codes.com/trouble_cod...-obd-codes.php
Maven's correct there is no listing for a B2AAA DTC, Is it possible the scanner you have cannot read BCM codes? I recommend that since the code is something you saw take it to the dealer and have them check the codes for any problems -- maybe the scanner you have has detected something but is incapable of showing "B" DTCs? Just a thought...
Thanks guys haven't been on here in a while and forgot I even posted this.
Haven't had the code checked yet but I will.
Probably correct that the scanguage II can't read the code correctly.
OrangeCoba
Sep 25, 2015 06:06 PM
