OBD II code B2AAA
Old Feb 21, 2009 | 12:12 PM
06_PurpleSS_Sedan's Avatar
OBD II code B2AAA
Anyone ever heard of this?
I got an 06 cobalt ss sedan, scanned it with a scanguage II and thats what it came up with.
Old Feb 21, 2009 | 12:15 PM
RS75GT 1SS's Avatar
That's definitely not a valid OBD II fault code.
Old Feb 22, 2009 | 06:01 PM
Maven's Avatar
Nope never heard of it. All B2000 series codes are set by the BCM or Onstar, though.
P2A00 is an Oxygen sensor code.
Old Feb 22, 2009 | 06:03 PM
BlueBolt66's Avatar
well couldn't tell you off top of head but I can try and look it up in my book at work tommorrow
Old Feb 22, 2009 | 06:36 PM
Maven's Avatar
No need, its not a code. Its not listed in the service manual.
Old Feb 22, 2009 | 10:08 PM
Spun's Avatar
I thought all B codes were non powertrain codes.
Maybe the OBD2 sensor the OP has is not able to fully pick it up and just gives B2AAA
Anyway heres a link to all the B codes hope it helps
(I didn't want to post them all, its along list)
http://www.obd-codes.com/trouble_cod...-obd-codes.php
Old Feb 22, 2009 | 10:17 PM
Maven's Avatar
Correct, B is a Body code, the only two modules that set B2xxx codes in the OPs car are the BCM and the Onstar module. B2AAA isnt a legit code
Old Feb 22, 2009 | 10:37 PM
Red07SSNA's Avatar
Maven's correct there is no listing for a B2AAA DTC, Is it possible the scanner you have cannot read BCM codes? I recommend that since the code is something you saw take it to the dealer and have them check the codes for any problems -- maybe the scanner you have has detected something but is incapable of showing "B" DTCs? Just a thought...
Old Mar 28, 2009 | 07:10 PM
Thanks guys haven't been on here in a while and forgot I even posted this.
Haven't had the code checked yet but I will.
Probably correct that the scanguage II can't read the code correctly.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
