Odd Problem
Old Feb 14, 2008 | 12:38 PM
an0malous's Avatar
thats bad.
Beck's Avatar
Originally Posted by an0malous
thats bad.
ugh not what i wanted to hear lol. so what else could it be? or is the ecu just toast?
Old Feb 14, 2008 | 12:43 PM
an0malous's Avatar
that would be my guess :/
how does the DIC/guages react when you turn the key on?
Old Feb 14, 2008 | 01:05 PM
Beck's Avatar
when i turn the key they'll light up like they should and display things like door/trunk ajar.
fuuuuuuuuuuuuuuuuck.
that is all.
Old Feb 14, 2008 | 01:10 PM
HackAbuse's Avatar
How were you tuning?
Old Feb 14, 2008 | 01:14 PM
YellowLT's Avatar
If it is saying door ajar thats the BCM
Old Feb 14, 2008 | 01:53 PM
Beck's Avatar
HPTuners. all i'll have to do is upload a new tune if i get a new ecu
okay so im assuming when i put the intake manifold back on i bumped the ground wire on the starter or something because if i start the car then remove the battery connection the car will run perfectly. so im guessing the ground on the started is fucked up and it cant be the ecu.
Old Feb 14, 2008 | 01:59 PM
RaineMan's Avatar
check the junk yards... you might be able to get one on the cheap.
Old Feb 14, 2008 | 02:29 PM
Beck's Avatar
a starter? i dont think its the actual starter itself i think its just not grounding properly. They're very sensative i suppose.
okay well i tightened down the ground and its still cranking when i connect the battery! Ugh
Old Feb 14, 2008 | 02:35 PM
HackAbuse's Avatar
Can the Starter only get power from the battery and not the alternator?
If that's the case, I'd be more than willing to bet it's the relay.
Like I said, disconnect the starter from the car and hook power directly to it and see if it cranks then, that'll tell you for sure
Old Feb 14, 2008 | 02:38 PM
  #36
3fo893013L's Avatar
Originally Posted by Super_SS
warranty ftw
fly bys at the airport
Old Feb 14, 2008 | 02:43 PM
  #37
RaineMan's Avatar
I didn't mean the starter... I meant the ECU.
Old Feb 14, 2008 | 03:20 PM
  #38
Beck's Avatar
figured it out. it was the battery cable itself coming in contact with the power wire mounting screw. so basically the battery was giving the starter power directly, which is why it was able to crank without a relay or fuse.
im guessing when i put the intake manifold back in it bumped the battery cable and caused it to shift.
case closed lol.
Old Feb 14, 2008 | 03:22 PM
  #39
nramlow2006's Avatar
Old Feb 14, 2008 | 03:32 PM
  #40
HackAbuse's Avatar
Glad to hear it
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
