Oil leak after stage 2 install...
so yesterday after stage 2 install, i drove home and poped my hood to see oil everywhere, freaked out and called them back they said they probably forgot to push the dipstick back down (it was up) so no big deal, i push the dipstick down, and clean up the mess and call chris, he tells me that my intake manifold gasket is probably gone.... so later that night i washed my motor down....
today i installed my ZEX plugs (that i love btw AWESOME) and take it for another rip..... i come home pop my hood and there it is, OIL, but my dipstick was still down, it looks like its leaking out from in under the supercharger........ or block area....i cleaned it again, and took it for a rip, and its back again.... so this bitch is leaking oil. attached are some pics..... what do you guys think????
you cant really tell from the pics, but this is the areas it looks like its commin from
The gasket for the supercharger cost about 50 bucks already check on it when i got a quote for my stage 2 install but the gasket is metal or aluminum what ever so they must of put it on wrong or they fucked it up putting it back on but yeah they told me i should get one for the stage 2 install
no one has any idea??/?
Last edited by saunders1986; 04-21-2007 at 02:38 AM. Reason: Automerged Doublepost
I would be willing to bet that the supercharger gasket was either improperly re-installed or damaged. Not a big deal as long as they get it taken care of soon.
what i'm tryin to figure out is why oil would be leaking outta the s/c gasket, i mean i didnt think there was oil up in there, i thoth the s/c's oil was self contained.....
The supercharger's oil is self contained, but when the vehicle is not under boost and is in a vacuum, it sucks up a little bit of oil from the motor itself. That is why it is a good idea to have a "catch-can" or "seperator" installed to stop oil from getting sucked into the supercharger. It will cause it to wear out prematurely and why they do not come with one from the factory is beyond me.
Here is a link to one.
http://www.modernperformance.com/all...catchcan.shtml
sounds like the S/C gasket definately needs replacing.
Bet your glad you went with GM stage 2, instead of the cheaper ghetto version.
Good luck with it. hope gm fixes it up quick.
try checking your coolant for any abnormality's. if theres oil mixed in there it could be an intake gasket, or turn the car on and look at the reservoir tank to see if it bubbles to see if its a head gasket. It might take a while for the bubbles to come through the lines but they will come if its leaking.
my friend got stager 4 installed and on the way home he heard knocking and when we got home there was oil every where and he didnt have warrenty because of mods he took it to royal chevy and the said it was a shot piston and it cost him 6,000 and they gave him brand new supercharger and motor (now for sale 16500 ) hit me up and ill let him know
