oil light comes on after oil change.
Old May 3, 2007 | 04:05 PM
louiefan's Avatar
my oil light has been coming on since ive gotten my car abck from an oil change, this is two weeks ago, i brought it in, they check filter and all, nothing is loose, but the light continues to come on, i have plenty of oil in it.. the thing is that my dad gets it when he drives and i never do. he tends to run in 2 or 3'd gear when it should be in the one above it. any ideas or the same problem, and when the light comes on, you can idle it for 15 minutes yes i did it, and it will stay on, but as soon as you tap your foot on the gas, it goes away.
Old May 3, 2007 | 06:48 PM
bluecobaltss06's Avatar
Sounds like there isn't enough oil in it. If it's under warranty take it to the dealer let them chcek it out
Old May 3, 2007 | 07:02 PM
louiefan's Avatar
theres plenty of oil in it, i check it almost every 3 days just to see if its going down, but no dice.
Old May 4, 2007 | 01:35 AM
When it comes to your oil light you shouldn't take anything lightly. Get it checked out. For all you know it could be somthing as serious as the oil pump failing, or maybe it's something as simple as the oil pressure sensor going bad. Get it checked out and put a post up, I'm kinda curious what's going on.
Old May 4, 2007 | 01:41 AM
cobaltcoupe's Avatar
Get that checked out right away. You don't want to seize up the engine.
Old May 4, 2007 | 04:55 PM
Coblasts's Avatar
Had that problem with the same symptoms you describe with another car and it was the oil filter.
For the few dollars just try changing the oil filter and see if it goes away.
If not get it to the dealer right away could be a legit pressure problem.
Old May 5, 2007 | 10:32 AM
louiefan's Avatar
yeah, isnt the filter for the eco tec inside it, someone showed me at work how to but i completly forget, any words?
Old May 5, 2007 | 10:35 AM
D4u2s0t's Avatar
i'm assuming you reset the DIC?
Old May 5, 2007 | 10:50 AM
jojot's Avatar
Does the light say low oil pressure or check engine oil level?
Old May 5, 2007 | 11:56 AM
louiefan's Avatar
no, it dosent give me any warnings except the light that comes on, and yes i reset it 2 minutes after i got the change done.
Old May 17, 2007 | 12:30 AM
Hitman's Avatar
The oil filter is a drop in under the supercharger.
Old May 17, 2007 | 01:35 AM
WopOnTour's Avatar
The oil filter needs to be removed and inspected and the check valve "nipple" (on the bottom of the filter) checked for damage
Sometimes the nipple from the old filter might have broken off where the filter cap is tightened when a misalignment exists and then the new filter doesnt seat properly
Wop
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
