oil light problem
Old Apr 21, 2012 | 02:44 PM
98gsx's Avatar
oil light problem
Okay I just got done replacing the timing components. On start up it was kinda loud and died down once oil got to it. Now I go to test drive it and the oil light comes on.
I checked the dipstick and it's fine.
What could the problem be?
Old Apr 21, 2012 | 03:02 PM
bluebalt07's Avatar
Did you check the dipstick with the moor running or wait til it was off and cooled down?
Old Apr 21, 2012 | 04:27 PM
98gsx's Avatar
I checked it with the motor off and hot? Now its just flickering on and off. Not sure if its the oil pressure sensor or not. The car was sitting for a month if that helps.
Old Apr 21, 2012 | 04:47 PM
nhanson's Avatar
I wouldnt be running a car with the oil light on till the problem is fixed
Old Apr 21, 2012 | 05:04 PM
bluebalt07's Avatar
Check the oil when the motor is cold to see if the level has gone down then. If it is still within the acceptable range on the dipstick, maybe it's just the sensor
Old Apr 21, 2012 | 05:33 PM
98gsx's Avatar
Yea I already ordered the sensor. I will get back to y'all Tuesday to see if its fixed.
Old Apr 21, 2012 | 06:32 PM
98gsx's Avatar
Lol I forgot to tell y'all its for a 2.4Le5. Didn't know if it was common for theses motors.
Old Apr 22, 2012 | 05:53 PM
Coblasts's Avatar
Had a similar problem on another car and it was the oil filter.
Oil light flickered at Idle only ,if the rpm was raise a bit it would go out.
Old Apr 24, 2012 | 12:02 PM
98gsx's Avatar
New sensor, same problem. So I pull the oil filter out and Started the car and very little oil pressure was seen from that area. So next is to pull the oil pan and see if the pick up tube is clogged.
Old Apr 24, 2012 | 12:09 PM
K-Train04RL's Avatar
Check the pick up. If u had to replace timing guides and such u could be clogged
Old Apr 24, 2012 | 03:16 PM
98gsx's Avatar
I will check the pick up tube tomorrow. Now I do remember tightening the little oil thing that supplies the chain with oil. Maybe it was to tight and cracked it?
Old Apr 25, 2012 | 02:12 PM
98gsx's Avatar
Okay I found the problem!!! It was a clogged pick up tube. A paper towel dropped in the oil pan and got stuck in the pick up tube. Anybody know how to put resolved on this thread?
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
roth
Sep 26, 2015 12:16 PM
