oil pan help
Old Feb 3, 2008 | 09:42 AM
BIG-DAVE's Avatar
oil pan help
ok so i'm taking off my oil pan to tap it and it wont come off i took all the bolts out but it still wont drop i even tapped around the edges ..................anyone
Old Feb 3, 2008 | 12:35 PM
Maven's Avatar
Okay, youre sure you removed all the bolts? There should be 15 bolts that hold the pan to the engine and you need to remove the lower a/c compressor bolts too.
Then its just a matter of prying. The sealant that is used is good stuff. Its strong.(make sure you use the same stuff when you go back on, Permatex offers it now, Ultra Grey, i think its #82194
Old Apr 5, 2008 | 06:00 PM
mrsilent13's Avatar
so i got the same issue....as i was trying to pry the thing off....it just wouldnt budge...i started kicking it and hammering at it with a rubber mallet.....any other suggestions for me?
well after about an hour of not being able to get it off i just put everything back together...but if someone knows a good way of doing it please let me know wat the trick is.....and yes i took all the bolts off....i triple checked...help me please
Old Apr 5, 2008 | 06:06 PM
Maven's Avatar
There is no trick, just pry it off. There should locations on the corners near the transmission where you can get a good bite with a pry bar. You can try heating it up along the rail to make the sealant a little more plyable, but honestly Ive never had to resort to that, a deadblow/soft faced hammer and some prying implements is all you need.
Old Apr 5, 2008 | 06:12 PM
mrsilent13's Avatar
i hope so....ill probably get to it later....oh and do u remember wat size the feed line nipple was....was it a 4an to 3/8"npt or was it a 4an to 1/4"npt
Old Apr 5, 2008 | 06:13 PM
BIG-DAVE's Avatar
yea .. like he said its just amatter of pryin the hell out of it ... the sealnt they use is tough hitting it with a hammer really isnt going to do the job ..
DarrenGC
Dec 24, 2021 01:55 PM
biniecki
Oct 25, 2015 02:23 PM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
