Oil Pan leak
Old Jun 29, 2015 | 11:46 AM
Olybaltss's Avatar
Oil Pan leak
I checked threads but there aren't too many that give detail. If my oil pan is leaking, do i have to drop it entirely, or remove nuts/bolts, and then pry the lower half from the upper and reseal it while the top of the pan is still attached to the car?
Old Jun 29, 2015 | 11:50 AM
hawkssoccer11's Avatar
that would be the smartest thing to do because who knows what else could be wrong, but most likely the gasket as long as you dont have a hole in the pan itself
Old Jun 29, 2015 | 12:05 PM
Olybaltss's Avatar
i'm fairly sure it's the gasket, it runs along the crack between the two pieces. I've been under and checked it out, just didn't get much clarity on the "removal" process in other threads. because they don't drop it completely, it makes sense.
Old Jun 29, 2015 | 12:11 PM
umrdyldo's Avatar
Unbolt
Carefully pry oil pan off. Carefully.
New gasket,
Maybe a very light coating of RTV to seal it well.
Old Jun 29, 2015 | 12:31 PM
chris88z24's Avatar
The LSJ doesn't use a traditional gasket, it uses sealer. Use Permatex "the right stuff"
Old Jun 29, 2015 | 12:56 PM
umrdyldo's Avatar
Quick search showed this is the GM stuff
Amazon.com: Genuine GM Fluid 12378521 RTV Engine Sealant - 5.3 oz. Cartridge: Automotive Amazon.com: Genuine GM Fluid 12378521 RTV Engine Sealant - 5.3 oz. Cartridge: Automotive
lay a 3.5mm bead around the perimeter of the oil pan and oil suction port opening.
Old Jun 29, 2015 | 01:03 PM
Olybaltss's Avatar
This is what i got. My biggest question was making sure the whole oil pan doesn't come down, which seems to be the case. Thanks for the help everybody.
Old Jun 29, 2015 | 02:33 PM
chris88z24's Avatar
It's stuck on there pretty good by the sealant. Be careful when taking it off not to damage the bottom of the block. Follow the bolt pattern and torque sequence in the service manual and don't forget to put the sealant around the oil pickup port or else you won't have oil pressure.
Old Jun 29, 2015 | 02:36 PM
Olybaltss's Avatar
Awesome, I don't know that i would have known this.
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
